Can these 4 drugs disqualify you from CDL?
Discussion in 'Driver Health' started by Rahat, Mar 25, 2023.
Thread Status:
Not open for further replies.
  1. Rahat
    Rahat Light Load Member
    208
    197
    Feb 23, 2023
    1. Lorazepam: Anxiety and muscle relaxer
    2. Citalopram: SSRI depression medication
    3. Amitriptyline: For neck pain
    4. Quetiapine(Seroquel): For sleep
    Pain causes anxiety and then anxiety causes stiff muscles and more pain. It is a vicious cycle. So anxiety medication is more for pain than for anxiety.
  3. Rahat
    208
    197
    Feb 23, 2023
    @Moose1958 Thank you for your contribution. God bless!
  4. Rahat
    208
    197
    Feb 23, 2023
    Believe it or not, pain also increases blood pressure.
  5. Moose1958
    Moose1958 Road Train Member
    15,090
    33,172
    Dec 17, 2010
    Williesburg, Virignia
    NO to all 4 of them. Here's the rub. Unless you are using any of the prohibited and tested for substances unless you tell on yourself there is no way for anybody to know. None of those 4 substances are part of the DOT urine test.
    Your question was a specific question of whether they are disqualifying, that answer is NO. Should you take them is another chapter of the book.
  6. Rahat
    208
    197
    Feb 23, 2023
    I believe in honesty is the best policy. I will declare all 4 in the form. Will the DOT doctor pass me?
  7. Chinatown
    Chinatown Road Train Member
    73,270
    164,630
    Aug 28, 2011
    Henderson, NV & Orient
    Even if the doctor passes you, no trucking company will hire you. Trucking companies will think you have mental problems and won't take the risk. If you have a wreck the company can go bankrupt in a lawsuit.
    Most companies want a copy of the long form physical which shows everything about the physical. They keep that on file.
    Don't drive until you're completely off those medications.
    Moon_beam, Rahat, Kyle G. and 2 others Thank this.
  8. Kyle G.
    Kyle G. Road Train Member
    3,757
    19,623
    Jan 23, 2016
    Eastern Iowa
    I’m not hating, but my opinion is the drugs are irrelevant in this case. Get the pain and the anxiety figured out before you drive a truck, because if pain and anxiety are that big of an issue for you, then you will be miserable as a truck driver.
  9. Tb0n3
    Tb0n3 Road Train Member
    4,279
    8,194
    Oct 5, 2012
    Earth
    Does staying silent count as lying when you're writing down your meds? Really, if mentioning it can only hurt you, why say anything. The DOT physician is not your doctor, and so they don't need to worry about drug interactions.
    Rahat Thanks this.
  10. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    390
    1,713
    Jun 22, 2022
    Lorazepam side effects: drowsiness, dizziness, tiredness, weakness, unsteadiness.
    Amitriptyline side effects: drowsiness, weakness, tiredness.
    Seroquel side effects: Feeling sleepy during the day - do not drive, cycle or use tools or machinery, mood or behavior changes, drowsiness, dizziness, lightheaded, tiredness, headache, trouble sleeping,
    Restating Seroquel side effects: FEELING SLEEPY DURING THE DAY - DO NOT DRIVE, cycle or use tools or machinery.
    80,000 pounds at 75mph.
    If you need those to maintain life, seek a non-driving profession.
  11. Concorde
    Concorde Road Train Member
    4,345
    15,431
    Jun 29, 2016
    West Melbourne Florida
    Probably not..unless you’ve been on the Lorazepam for a long time without some of the side effects.
    It’s a nasty drug and I’d think long and hard before ingesting any of it.
    Honesty is best on this issue because your to be employer can submit to to a 10 panel test if they want.
    Also should you ever get in a serious accident and it comes out than you could be in a world of legal hurt.
    Hope you talked with a Pharmacist before taking all that crap together.
    Good luck.
    Rahat Thanks this.
  • Thread Status:
