My turbo boost has been working then stop working. Don't know if it is just a sensor. Thanks
Can someone please tell me where the boost sensor is for turbo on cummins is cm 871
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Sep 8, 2014.
http://www.thetruckersreport.com/tr...ummins-isx-cm871-engine-sensors-location.html
Print those you will probably need them. Picture 3 item 3 "intake temp/press sensor" Thanks again HeavyD.
Heavyd Thanks this. -
as I remember sensor is whith digital output, not compatible with CM870
http://www.thetruckersreport.com/truckingindustryforum/trucks-eighteen-wheelers-/224247-cummins-isx-cm870-engine-component-charts.html
this is the 870 chart if you need it. Thanks again HeavyD... The OP asked for boost sensor on a 871.Heavyd Thanks this.
