Okay so I bought my first trailer for an excavating business which is an 86 eager beaver 20 ton tag along. When I picked it up I didn't air it up then when I got back to my shop I applied air and the brakes would not release. So I put a new relay valve in the trailer and now the parking brakes works fine but when I hit the services brakes the brakes lock but won't release. There's is air pressure on the blue gladhand I have to take it off to release the brakes. I'm wondering if it's on my truck the problem when I push in the red trailer knob and step on the brake pedal a constant air supply comes out. So does anyone know what would cause this? I need my trailer next week to move my machines I'm going broke here. Any help is greatly appreciated!
Can someone please help me with my trailer air brake problem???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Supertrucker47, Sep 18, 2018.
Page 1 of 3
You might have a quick release valve that's gone bad.
Well I should say that when I first got it a couple months ago I had to put a new cab on because the cab was shot. I'm wondering if I hooked a hose up wrong. So I guess my first question is with the red knob for the trailer pressed in and my foot on the brake pedal should the air be continuous from the blue gladhand or only supply a set amount of air?
If service brake or Johnny bar is applied you should have continuous air flow from the blue and stop when let up. If a gauge is installed the pressure will go up the harder the pedal is pushed to match tank pressure @ max travel.
Release the brakes red In. With the blue gladhand off at the trailer. Any air coming out the trailer blue gladhand?jammer910Z Thanks this. -
The red hose charges the trailer air tanks and releases the spring brakes (has constant pressure when dash trailer button depressed) the blue hose has air pressure when brake pedal depressed or trailer brake lever is pulled only and should vent when released, you can check brake application gauge on dash to see whats happening there. The blue hose should be on the pass side of trailer and red on drivers side. Hope this helps
When brake pedal is applied, blue hose should pressurize when brake pedal is released blue hose should vent (through the truck valve) then relay valve on trailer should vent brake chambers.
bjrc said: ↑When brake pedal is applied, blue hose should pressurize when brake pedal is released blue hose should vent (through the truck valve) then relay valve on trailer should vent brake chambers.Click to expand...
Page 1 of 3
Related Categories
L9000 ford air filters
W923 posted Apr 24, 2025 at 10:33 PM -
2016 Peterbilt 579
Shane1993 posted Apr 24, 2025 at 7:50 AM -
84 IH 9670 front hub swap
Binderdavemays1 posted Apr 24, 2025 at 6:40 AM -
How is this possible??
rolls canardly posted Apr 21, 2025 at 11:00 AM -
SPN 520342 FMI 17 - Cascadia
sonnyca posted Apr 20, 2025 at 7:46 AM -
Volvo VNL 760 2024 SUNVISOR...
thearshsingh posted Apr 19, 2025 at 2:35 PM -
A/c cycling on and off
ran99 posted Apr 18, 2025 at 4:36 PM -
84 international 9670 front hub...
Binderdavemays1 posted Apr 18, 2025 at 10:25 AM -
Turn Signal Issue on 1980 359 Pete
Lancair posted Apr 17, 2025 -
2012 Durastar no high idle
dhoffman22 posted Apr 17, 2025
Loading...
Recent Threads
KW won't idle above 68F like...
DavidInPuyallup posted Apr 24, 2025 at 10:57 PM -
Springfield, MO to La grange, GA
Jtrucker1266 posted Apr 24, 2025 at 10:48 PM -
Jtrucker1266 posted Apr 24, 2025 at 10:47 PM -
N14 Purging air every 15 seconds.
1995w900 posted Apr 24, 2025 at 8:21 PM -
what's the best fuel card?
wookies posted Apr 24, 2025 at 7:30 PM -
Recruiter screwed me over
EDcantSTOP posted Apr 24, 2025 at 4:43 PM -
Looking for a team driver for...
Ktmorgan posted Apr 24, 2025 at 12:45 PM -
Alternator upgrade? 40si too...
ohandy1 posted Apr 24, 2025 at 12:16 PM -
Life Predicament and Lost
SpikezII posted Apr 24, 2025 at 11:59 AM
Loading...
