Can scale houses actually tell if I’m overweight on spread axles
Discussion in 'Flatbed Trucking Forum' started by Flatbed2222, Feb 26, 2022.
  1. Flatbed2222
    Flatbed2222 Bobtail Member
    7
    15
    Feb 26, 2022
    Front spread axle: 20640 lbs
    rear spread axle: 18820 lbs
    (Overall spread: under 40k lbs)
    Total weight: 74600 lbs
  3. Judge
    84,417
    They don’t usually axle out a spread, you’re allowed 40.
    12(more in some states) on steer, 34 drives, 40 spread
    I’d go as long as you’re not overgross
    And you have a 10’2 spread.
  4. xsetra
    xsetra Road Train Member
    5,094
    6,940
    Aug 21, 2011
    Some weigh stations do weigh each axle.
    Mattflat362, bumper Jack and CAXPT Thank this.
  5. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
    Ive had the scale house make me weight the spread axles separately at 2 places. Once in wyoming and other time was Illinois or indiana, cant remember for certain.
    Bean Jr., Flatbed2222 and CAXPT Thank this.
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Probably Indiana, they used to split your drives too. It’s wording in the regs. Technically if the axles are more than 10’ apart you get 20,000 per axle. It says nothing about 40,000 on a spread tandem. Just 20,000 if there’s no other axle within 10’. So from there it’s up to the guy in the scale. Other than the more fascist jurisdictions nobody is going to mess with you as long as you don’t blow over 40,000 on the pair, but that wording is still there.
  7. beastr123
    beastr123 Road Train Member
    2,803
    22,846
    Jan 2, 2014
    Moose Jaw SK CAN
    Consider lowering your ride height on your trailer and raising your drives(max 3/4 inch), this will equalize your spread a bit. This is combination of load distribution and trailer level. The fifth wheel being effectively lower than the center of your spread loads the front of the spread more than the rear. Concentrated loads show this much more. flat angles.png
  8. supersnackbar
    18,597
    44,717
    Aug 19, 2007
    Your Town, USA
    Florida does on their estimator plates before they give the pull in or bypass lights. I got an overgross ticket, on the printout it gave me the weights of each axle, the spread length, the bridge measurement and my height and width (south bound near Ocala). And a former coworker got a ticket in NC because the mechanic who replaced the airbags put the wrong size airbags on the rear axle and it was carrying most of the weight.(had over 25k lbs on rear axle on glass trailer.
    stwik, Vampire, Rugerfan and 3 others Thank this.
  9. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    They did to me in Oklahoma. I was 1800# over on the forward axle and 4000# under on the rear. Got a ticket
  10. beastr123
    2,803
    22,846
    Jan 2, 2014
    Moose Jaw SK CAN
    I may be wrong concerning the state regulations of spread axles weight but some if not all can regulate the variance of weights per axle and even side to side. I believe most have a 2000 pound maximum variance, whether they enforce it or not.
    CAXPT Thanks this.
  11. CAXPT
    CAXPT Road Train Member
    2,930
    12,557
    Feb 10, 2008
    You've basically gotten your answer. Yes, they can. Most houses are now computerized to read that information as you get on the scale, the same way you can scale your load by moving on the scale axle by axle and then reading the amount as the next axle comes on. Most houses also have at least the 3 plates. Steer, Drives, and the long one for the total trailer axles. I've had to have loads that couldn't be loaded properly on a step removed for that reason, because whether they choose to enforce it or not, in the end, it is your responsibility if it is over and your gamble. :) Choose wisely grasshopper...and don't get peeved at them if they do enforce it.
