Can I use pb blaster as a starting fluid? I am stranded and that is all I have. Motor is a 3407b cat and usually starts right up
Can I use pb blaster as a starting fluid.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rick Wilmath, Oct 15, 2018.
I dont think so.
Do you have brake line de icer?BigBob410 Thanks this. -
No just the pb blaster
Yes it is a combustible, so it may work.
Grubby Thanks this. -
PB is flammable but doesn't really work. Brake line antifreeze will make you sorry I promise you. WD 40 works ok and of course that real Lucille starting fluid.
If worse comes to worse, call uber or a taxi & have them bring you a can of ether. Just pay the guy. Cheaper & faster than a wrecker or roadside service.
If they wont go buy it for you, just hop a ride & run get some... ah, ether.
Actually, one of the parts houses might bring it to you. NAPA, Advance & Auto Zone have runners.
Just a thought....... hope this helps.homeskillet, Grubby, Mattflat362 and 3 others Thank this. -
SAR, KVB, Grubby and 1 other person Thank this.
I have used spray paint. Turn cam upside down. Anything flammable works.
Oldironfan and Grubby Thank this. -
Aussies got some good stuff...
Crude Truckin', homeskillet, Klleetrucking and 3 others Thank this. -
Good luck.
