Can I use any antenna with my CB radio?
Discussion in 'CB Radio Forum' started by expedite_it, Mar 26, 2020.
  1. expedite_it
    expedite_it Road Train Member
    1,635
    852
    Sep 8, 2012
    I started trucking 7 years ago, but I have never had a CB radio until now. I bought a Cobra 29 LTD Classic CB Radio.
    Can I use any antenna made for CB radios with my Cobra 29 LTD Classic radio?
    I see a lot of 3500 watt antennas for sale at truckstops. I think 3500 watts is the most common wattage of antennas for CB radios. Can I use a 3500 watt antenna with my Cobra 29 LTD Classic? If not, what wattage antenna do I need?
    Are there any other features of an antenna that I need to check to make sure my antenna is compatible with my Cobra 29 LTD Classic CB radio?
  3. Finfn1372
    Finfn1372 Road Train Member
    1,912
    3,476
    Aug 7, 2014
    Greenville,NC
    What kind of truck do you have?
    Most antennas will work,but they might need adjusting.Go with some aftermarket co axle cable,the stuff in the trucks are junk.
    Sirscrapntruckalot Thanks this.
  4. expedite_it
    1,635
    852
    Sep 8, 2012
    I have a 2020 Freightliner Cascadia.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I don't know.
    What I do use is a Uniden PC76xl and that old radio has a function in which you could match whatever antenna you had on to it. If it "Knew" how big or how small of a antenna it was attached to, the quality of the conversation is adequate.
    My very first CB radio bought the afternoon I graduated Trucking School with a Class A was a basic cobra 19. Here is one example for sale on the bay. I never thought I would see one again.
    However. I soon disposed of the radio when I was educated with much bigger and better radios out there by everyone. They ridiculed my tiny little toy radio because it was just too basic at that time. (Not a bad radio but it was really basic.) It mattered not what antenna you put on. I think I used a wilson mag mount in car and a couple of generic firesticks for the truck. The little three foot ones with the rig being a cabover and you could not get too high.
    Cobra 19 Plus 40 Channel Mobile CB Radio Transceiver | eBay
  6. Finfn1372
    1,912
    3,476
    Aug 7, 2014
    Greenville,NC
    With a freightliner,most install on a bracket that connects to the mirror arm on the door.
    When I had my old freightliner,I bought a bracket,ran cable from the bracket under the hood,through the firewall into the truck behind the dash.
    Had a 5ft firestick,if you run off the arm I wouldn't run under 5ft.
    I believe @craig_sez has a freightliner,could be wrong,but he's the guy that could really help you with this,if he sees it.
  7. expedite_it
    1,635
    852
    Sep 8, 2012
    A mechanic is going to install the CB radio and antenna, not me. I'm just trying to find out what I have to know to make sure that my antenna is compatible with my Cobra 29 LTD Classic CB radio.
  8. Finfn1372
    1,912
    3,476
    Aug 7, 2014
    Greenville,NC
    If your just going to install in the factory location,with out running wire,I'd just go with a couple 4ft fiberglass antennas,maybe something that comes pretuned like Francis.
    When your ready for an aftermarket install you can change up than.
    expedite_it and CheeseCracker Thank this.
  9. CheeseCracker
    CheeseCracker Bobtail Member
    16
    62
    Sep 9, 2019
    Second Finfn 1372's post. Those Francis are great antennas for your basic radio setup. I would try to get a 5' if you can. The taller the better, but then you don't want it too tall or you might knock it off on tree limbs
    Finfn1372 Thanks this.
  10. expedite_it
    1,635
    852
    Sep 8, 2012
    What about the Wilson 3500 watt antenna? I see a lot of those for sale at truckstops.
  11. Finfn1372
    1,912
    3,476
    Aug 7, 2014
    Greenville,NC
    If your going stock,id stay fiberglass,but with ever you choose if its not pre tunned you're antenna 9 times out of 10 will need adjusting.
    I wouldnt spend alot on a antenna if you're gonna stay stock right now,the pre ran cable in these trucks are junk.
    expedite_it Thanks this.
