Can I install a Trailer brake in a truck that didn't come with one?
Discussion in 'Freightliner Forum' started by robbiehorn, Nov 16, 2013.
  1. robbiehorn
    robbiehorn Light Load Member
    143
    56
    Jul 18, 2010
    Axtell,Texas
    My truck is a old US Express Columbia & I am wanting to know what all is involved in installing a trailer brake handle in the dash. I see them on fleabay all the time. Does anyone know how much air line plumbing this would take? Is it all under the dash or do you have to run a bunch of new lines.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yes, U can.
    use air supply from park brake air tank (the better place to cut in T-fitting is in air switch manyfold area).
    Controll line runs under hood. Cut in "select hi" air valve in TCV control line in foot brake valve area.
    Run handvalve exaust to outdoors becouse you do not want to hear SHHHH sound every time u release trailer brake
    robbiehorn Thanks this.
  4. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    need a diagram?)
  5. robbiehorn
    143
    56
    Jul 18, 2010
    Axtell,Texas
    Yes a diagram would be helpful. By what you told me Pablo-UA I looked at it yesterday and I am pretty sure that I can do it myself. Thanks a lot for your help.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    post me e-mail.
    BTW, about valves. On all valves sold worldwide I cas see European port marking.
    1- supply
    2- output
    3 - exaust.
    Tank marking
    Wet tank ore supply tank - black lines
    I -Rear brakes - Green lines
    II. - Front brakes - Orange lines
    III - Park and trailer supply tank - lines are red
    IV- accessory tank
    Yellow - park brake deactivation
    Blue - trailer control line
  7. robbiehorn
    143
    56
    Jul 18, 2010
    Axtell,Texas
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    check email box
  9. bad-luck
    bad-luck Road Train Member
    3,252
    5,956
    Nov 16, 2013
    Baltimore, Maryland
    Yes you can. A couple hundred bucks if you pay a shop to do it
  10. robbiehorn
    143
    56
    Jul 18, 2010
    Axtell,Texas
    Got it Pablo-UA it was hiding from me in the spam box. Thanks for your time sending me the diagrams. As soon as I get the engine put back together this will be my next project. I had one in my other truck and I used it quite often.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    use only DOT ore ECE certified fittings. There are many chenese fitting on market that may pop up under pressure.
    I use made of metal push it fittings, but threaded are better.
    Fittings are the critical points of air brake system.
    Chenese fittings may be bad may be good, there are many makers there so I cant be ure what are of good quality, what not, that's why I prefere European ore US makers
