Can I get more power out of 11.1L early DDECIII?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dhtrucking, Jun 5, 2011.
  1. dhtrucking
    dhtrucking Bobtail Member
    I'm looking at a truck with a '93 (I believe) Detroit Series 60 DDECIII 11.1L. The guy says it has 400 hp but when I researched online and asked a Detroit guy they both told me that this engine can't be pumped up over 365hp. Is there any way to get more power out of this engine or is that pretty much it?
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    It may have been the DDECIV that went to 400HP, but I think most of it was to let the engine rev to 2000 rpm, instead of the 1800 that the older 350/365's had.
    And at one time you could reflash the ECM to upgrade them, but that might have been from II to III.
    dhtrucking Thanks this.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I am told you can have it at 365h.p # 1800 rpm or 350 h.p. # 2100 rpm. Everyone has told me you can not upgrade, all the dealers. e.t.c. but you can upgrade the e.c.m. Erich & Brad can do it & others also.
  5. dhtrucking
    How much does it cost to upgrade the ECM and how do I get ahold of the guys that can do it?
  6. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    I had my '96 11.1 DDEC III uprated to 400 HP... it was a great engine.
  7. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    I also had my '95 DDEC III uprated to 400, as did a friend of mine. You have to call Detroit instead of a dealer. Then you may have to insist there really is such a prigram.
  8. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Know this is an old thread. But found last night, that a 11.1 when upgraded to a DDEC IV ECM. They only have the 400 HP 1350 Torque program for it then. Seen a lot of info on the 365 HP up rating. And Read where some in the RV's had the 400 HP 1350 ratings. Then found the info where when you upgrade to the DDEC IV you only have the chose of 400 HP with it.:D
    Mine has the DDEC IV ECM on it. Guess it being 400 HP and 1350 is why it pulls so well.
  9. Hardlyevr
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    The 365 only went to 1800 rpm, and the 400 went to 2100.
    tnpete Thanks this.
  10. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    Yep. The HP is all in the upper rpm range.
    tnpete Thanks this.
  11. tnpete
    561
    609
    Jun 25, 2013
    Tn
    Mines 365 then, as it only turns 1800. That is at 78 MPH.
