Can I get cdl class b with combinations ??
Discussion in 'Questions From New Drivers' started by jesus1337, Aug 6, 2023.
  1. jesus1337
    jesus1337 Light Load Member
    162
    123
    Jul 24, 2023
    Cause I’m about to test tomorrow and can I add combinations I’m in Texas Houston area. Will that make me class a or b? My employer for class b is sending me
  3. ducnut
    ducnut Road Train Member
    2,425
    7,200
    Dec 31, 2010
    SPI
    Class B is a straight truck, weight restricted. Class A is tractor-trailer, not weight restricted.
  4. Moose1958
    Moose1958 Road Train Member
    15,088
    33,170
    Dec 17, 2010
    Williesburg, Virignia
    The Cass B is not weight restricted. A person with a Class B can not operate a trailer with a weight over 10,000 pounds just like a regular Drivers License. However, they can operate any single vehicle of any rated weight.
    I think I understand what you mean, in my opinion, you did not express it clearly! I only brought it up because there are a lot of people that do think there are rated weight restrictions on Class B.
    ducnut and Gridaxe5588 Thank this.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    811
    1,584
    Dec 15, 2021
    CDL B only required to operate this on a public road,weighs 132,000.CDL A if you hook up to a trailer.
    cke, ducnut and Gridaxe5588 Thank this.
  6. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    Not quite correct. A hotshot rig would be a Class A as well as a straight truck pulling a trailer (think dump with equipment trailer) is also a Class A. Those will have an O restriction which specifically prohibits driver from driving tractor trailer.
  7. Todd727
    300
    583
    Jun 7, 2021
    If you take a truck with a trailer, you will get a Class A with the O restriction. You won't be able to drive a tractor-trailer.
    That being said, you would've had to take the written for combination and done the ELDT theory for Class A. If your permit doesn't say Class A, you won't be able to test with a trailer behind the straight truck. If you didn't take the ELDT theory for Class A, you won't be able to test with a trailer either.
    Testing with this (without the excavator), would get you a Class A with an O restriction: 20230515_135522.jpg
    Gridaxe5588 Thanks this.
