Can I be forced to use 16 hour rule?
Discussion in 'LTL and Local Delivery Trucking Forum' started by Fatback, Apr 10, 2014.
  1. Fatback
    Fatback Light Load Member
    89
    30
    Jul 8, 2011
    Colchester, VT
    .. Can an employer force a driver to use the 16 hour rule for non emergency situations? I've heard that the driver has the option to use it (not forced). Have also heard that is for emergency situations...Break downs and the like.. A areference would be good .
  3. Doud
    Doud Bobtail Member
    11
    6
    Jul 6, 2012
    Salem,Alabama
    No they can not.
    Dominick253 Thanks this.
  4. TomOfTx
    TomOfTx Road Train Member
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    To answer your question, NO, you can not be forced. If you are fatigued, you are protected under §392.3 Ill or Fatigued Driver. You can however be on duty up to 16 hours, but only if you comply with the terms of §395.1 of the FMCSR.
    Property-carrying driver. A property-carrying driver is exempt from the requirements of § 395.3(a)(2) if:
    (1) The driver has returned to the driver's normal work reporting location and the carrier released the driver from duty at that location for the previous five duty tours the driver has worked;
    (2) The driver has returned to the normal work reporting location and the carrier releases the driver from duty within 16 hours after coming on duty following 10 consecutive hours off duty; and
    (3) The driver has not taken this exemption within the previous 6 consecutive days, except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by § 395.3(c).
    http://www.fmcsa.dot.gov/regulations/title49/section/392.3
    http://www.fmcsa.dot.gov/regulations/title49/section/395.1
  5. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    They expect to get the use of every hour u got. but if you're being forced,its time to turn your keys in.
    Matt1924, Dominick253 and OPUS 7 Thank this.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    There is no limit to the duration of your on-duty status. The only limitation is that you may not DRIVE a CMV after 14 hours since you first went on duty until you complete a 10 consecutive hour off duty period. This can be extended to 16 hours for drivers who return to their work reporting location daily, have not taken a 10 hour break without returning to the work reporting location in the last 7 days, and MUST use the 16 hour exception to return to the work reporting location. If you take your 16 and don't make it back, then it's a violation.
    Again, you can be on duty for as long as the company wants you to be, you just cannot DRIVE beyond that 14 hours without a 10 hour break.
    edit: The 16 hour exception can only be used ONCE in a 7 day period.
  7. Moving Forward
    Moving Forward Heavy Load Member
    737
    727
    Jan 14, 2014
    New England, USA
    That's a great question, Fatback. Although it doesn't seem right to me, I know of several companies that will regularily try to force drivers into 16+ hour days... and there's not a lot we can do about it other than find a better company to drive for. I've only been doing this for four years, but it has amazed me how many companies will try and push drivers to run illegally and/or beyond their personal limits. Good luck with your situation.
  8. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Not entirely true...
    "except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by § 395.3(c)."
    This means it could be used on a Friday, reset over the weekend then use it again on a Monday.
    windsmith Thanks this.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    You can only be forced if you let them....
  10. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    As fast as the DOT makes new rules or tries to enforce the current rules these companies try to get around them .
    ..... be very afraid :biggrin_2555:
    NavigatorWife Thanks this.
  11. Fatback
    89
    30
    Jul 8, 2011
    Colchester, VT
    FYI I work for Conway freight... For what it's worth
    Matt1924 and Dominick253 Thank this.
