Can I be exempt from ELD
Discussion in 'Ask An Owner Operator' started by Rubens, Feb 18, 2025.
  1. Rubens
    Rubens Bobtail Member
    6
    I just bought a truck in NC to deliver my own products. It's a 14,500 lb box truck. I got a DOT number. I will be doing deliveries twice a week. I will also be driving under 150 air miles. It seems to me that I could apply to be exempt from ELD but I can't figure out how to get the exemption. Anyone can shed a light? Calling, chat or email to the FMSCA has been impossible.
  3. Judge
    84,608
    Call the dot or highway patrol in your state.. most officers will answer questions. Like agriculture products here are 150 mike exempt and other products such as sand was only 100 air mile exempt.
  4. Rubens
    6
    Will try Hwy Patrol. Thanks
  5. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    I understand the 150 mile exemption is open to anyone. You just do it. No piece of paper or approval is required.
    The DOT will use BOL's and fuel records to determine if the exemption is misused during an inspection.
    I think you will need to keep a log book or daily time sheet.
  6. OldeSkool
    OldeSkool Road Train Member
    1,650
    4,495
    Jul 17, 2018
    New Hampshire
    As long as your home address is in your 150 mile radius your fine. I’ve ran under it for 10 years. Your are supposed to keep a timesheet of your hours ran, but you are not required to have it in the truck. It can be at home in your office.
  7. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Sounds to me like 2 exemptions apply?
    150 air mile &
    8 day
    Just run a time card & leave it at the barn/home 20
    I run paper because of 31yr old truck.
    Nobody gave me an actual exemption document to show
    Rideandrepair and OldeSkool Thank this.
  8. roundhouse
    roundhouse Road Train Member
    3,130
    7,041
    Jul 11, 2018
    You don’t need an exemption from the state in writing .
    you’re exemption is written in the rule book
    if you’re inside the air mile radius from your home terminal , you don’t need a ELD or a logbook
    you are required to keep a time card but it can be kept at your terminal
