Can anyone tell me if I'm able to get away with a single axle daycab?
Discussion in 'Ask An Owner Operator' started by Migueljs16, Feb 22, 2013.
  1. Migueljs16
    Migueljs16 Bobtail Member
    32
    6
    Nov 10, 2012
    Allentown PA
    I'm seriously considering selling my truck, I was offered 39k cash, much more than i paid for the truck (I got a very sweet deal off ryder), 30k. This is all part to the deal my cousin got me.
    My cousin works in ryder (he is a location manager) got me a rate I could not believe on a single axle daycab: $105 a day, 15 cents a mile.
    Apparently no one rents the single axles, they've been sitting there and trying to rent them for months/years to no use, and he got me the rate that the company BARELY makes any profit at all.
    Here are my figures:
    2003 Kidron 48 x 96 with 3k hours on the reefer, got it off ryder.
    I place more or less 25k-30k pounds of cargo on the trailer.
    Single axle daycab 2007 INT 8600 (they got 3 of them) with a CAT C13A 425HP
    I get 18-20 pallets, about 2/3 weight less than 1k pounds, while the really heavy ones are the ones I would put in the back.
    I figure I put space in the back, since I always have it, if I got 8 feet of empty space, I'll make 8 feet of space THEN start placing my pallets from the "new Back" to the doors.
    Can I safely go through the weight stations with the single axle? or would I be pushing my luck?
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    $105/day plus 15cents/mile is a sweet deal ? If you run 2000 miles/week that comes to $4455/month ! you could make payments on 4 trucks with that kind of money.
  4. Migueljs16
    32
    6
    Nov 10, 2012
    Allentown PA
    I only need it 3 times a week for 220 miles roundtrip.
    If I buy a new truck and it breaks, it MAY be covered under warranty, but I'm screw with the cargo I have on hand at the moment, ryder brings me a new truck on the spot, and I can carry on.
    So is more peace of mind.
    No maintainance, no keeping track of miles, and paper work, just pay and drive.
  5. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    OK, just off the top of my head, I'll figure an axle with tires weighs about 2k lbs. So, an empty truck (single axle) coupled to a 48' reefer should weigh about 28-29K. Now load 30K on this unit and you've got under 60K gross, right ? You can put 12K on the steers, 20K on the drive and 34K on the trailer, which equals 66K . So in theory, you should be OK, however, I'd hook up this unit, weigh it empty, then load it and weigh it again, just to make sure. I would also say it would be hard to get 12K on the steer and 20K on the drive axle.
  6. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    Also do you have cargo insurance on the trailer to cover any accidents.
  7. dannythetrucker
    2,856
    4,032
    May 26, 2011
    everywhere, man
    Well, if your trailer weighs 14k and the truck prolly only weights 16k, your probably well under 30k to start with, PA allows 73,280 gross on 4 axles and 22,400 on that drive axle if it is registered for that weight, (may only be registered for 20k).  You say you only put 25-30k of cargo so you're only gonna be grossing 60,000.  I got a feeling you wouldn't even need the spacer in the front and you'd be fine.  Just have them load it even front to back and slide your trailer axles forward to pick up the extra weight.
    also, PA allows 36,000 on the trailer so you have plenty of leeway on both ends, it would be hard to screw it up only putting 30k on.
  8. Powder Joints
    7,506
    7,408
    Sep 25, 2007
    Rosamond, SoCal
    Your only allowed 20k max on the drives, 34k on the tandems, this is a real risky setup, imho. By the way I drive a 2 axle and have for the last 10 years. unless your oing to pull double by a 3 axle. Your tractor/trailer weight will probably be in the neighborhood of 26k empty, but you will not be able to gross 80 you will only be able to gross 12,20,& 34 axle wise, or 66,000. with a tare at 26,000 you can net 40,000. now loading this is going to be fun, and worse the handling with 65% of the weight in the rear of the trailer is going to be a nightmare setup to jackknife. Over all this is a plan for disaster. Buy a 3 axle so you will at least be able to load it safely.
  9. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    not to mention if he slams on the brakes with 8ft in the nose, and no blocking he'll have a cargo claim from hell specially with reefer. I have a feeling he'll have some problems with weight on that drive axle as well unless he's got his tandems all the way up. He'll have an extra 2k on the drive as opposed to a van I don't know a whole lot about calculating weight on pallets and where to put them in the trailer but in order for everything to be safe He'll be over on his drive. You bring up a good point with your jackknife. I'd rather get nailed for being over on drives than load heavy on the rear and spin the truck around. Personally I agree with you I'd say stick with the twin screw. And at least he'll have a power divider in the winter.
  10. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    The only way to know if you can do this or not, is for you to give a bit more information about WHAT it is that you are doing. You say you are only running two days a week, and it appears that it must be something that is pretty close to home. But how much of a variation do your loads have. And how much variation do you NEED to have the capacity for, in case whatever you are working now should come to an end.
    There are a lot of single screw tractors out there, doing a lot of different things. But when it comes right down to it, unless you are convinced that what you are doing is NEVER going to require anything bigger, you are better off staying with a three axle. It also gives you a lot more stability on less than ideal driving conditions.
    hup Thanks this.
  11. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    33 years ago I bought my first truck, a single axle Louisville with a single axle high boy trailer. That worked pretty well, but customers wanted bigger loads than I could handle, so I bought a tandem trailer with sliding axles. Then I could take the bigger loads, but also then some other issues started. I was often heavy on the drivers, and, in winter and in mud, I was forever getting stuck. No locking diffs back then. After a couple of years of fighting stuck and heavy, I went to a tandem tractor. Much better for what I was doing. So...unless you can get your loads to a science, and, if you can guarantee you won't ever have to drive in ice or snow with it, I would not recommend it. I was never in a situation requiring a quick or unexpected stop either, but that was early eighties out on the "frontier". Not nearly the traffic we have now. So there are 3 major issues for you to think about- weight problems, getting going, and getting stopped. I'd give it some careful consideration if I was you. Don't get blinded to these things by the visions of those profit dollars rolling in. They aren't going to mean much when you are stuck at an off ramp stop sign in 3" of new snow with a line of irate drivers lined up behind you wondering why you aren't moving.:)
    kerosene jockey Thanks this.
