Can a uhaul truck tow a 31ft travel trailer for 20-35 miles?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Ddr1992 579, Dec 28, 2019.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    I'll be using a 10ft uhaul truck or a 15ft uhaul to tow a 31ft travel trailer for 20-35 miles... Uhaul says there 10ft can tow 8600lbs and there 15ft can tow 10,000lbs... It should be fine, but i would like professional driver opinions and any help would be appreciated thank u
    LtlAnonymous Thanks this.
  3. LtlAnonymous
    6,084
    21,039
    Dec 23, 2016
    As long as the engine and the hitch can handle it, go for it. Just be very careful hooking it up, and don't skip any steps. My family found that out the hard way when I was a kid. Lol
    Lite bug Thanks this.
  4. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    I'm sure U-Haul employees could tell you horror stories of what people tried to pull with their trucks. Travel trailers generally don't weigh a lot, unlike, say a load of steel, you should be fine. Those things have the power of a moped, so it will be slow going, and probably for the best.
  5. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    I think I can answer this as one of my businesses is a u-haul dealership.
    Although u-haul has trucks capable of pulling that size camper (15ft, 17ft, 20ft, and 26ft trucks) the problem I think your going to run in to is the ball size.
    Most all U-haul trucks have a fixed 2” ball that is welded in to the bumper and not changeable.
    Most campers of the size you are talking about use a
    2 5/16” ball.
    U-haul has the welded 2” ball because most every size u-hall trailer uses a 2” ball hitch.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    It you have an equalizer hitch, no problem.
    Other wise , keep the speed down. For that short of a distance. No more than 55, maybe even 45. A speed wobble you do not want to experience.
  7. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    You'd probably be better off calling a friend, and using their truck.
  8. baerpath
    baerpath Light Load Member
    57
    77
    Nov 2, 2019
    Another thing is be very careful if it's a box truck when you turn. Camper fronts are not that strong
    jammer910Z and Cabinover101 Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    And that big ### trailer is going to seriously wag the dog. Please whatever you do do not put the little 10 foot puppy on there.
    Mooseontheloose Thanks this.
  10. Grumppy
    3,051
    10,341
    Dec 11, 2010
    West Monroe, La
    So you need to find out how much the trailer weighs. You'll have your answer. As long as the trailer weight is under the max towing weight of the truck you're using & the ball size is correct...... (oh, & you lay off the Tequila)..... I don't see any reason you can't tow it.
    Mooseontheloose and TokyoJoe Thank this.
  11. jeffman164
    jeffman164 Medium Load Member
    594
    557
    Dec 4, 2012
    Listen to what Hulld said before you waste your time.
