Can a steer tire be patched?
Discussion in 'Ask An Owner Operator' started by Dadetrucking305, Aug 7, 2022.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    I have a good steer tire that got a small puncture in it so I put a plug as a temporary fix to get me to the drop off location two hours away.Will it hold if I cut the plug ends off flush in the inside and then patch the bottom? I’m only debating doing this because the tire is in really great condition.
  3. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    I have had a steer patched before. I think the rule of thumb is not to patch it more than once.
  4. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i supposed you could.
    but every single company i ever worked for replaced the tire, with another new one. that tire, can be patched, then used on the trailer, or even the drives if the size is the same.
    not too many people take chances on patched steers, they do too much work as it is.
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Any plug you put in a steering tire makes it go to a tire shop and get a patch put on the inside of it and put on trailer or drive or just carry it for a spare.
  6. Hammer166
    7,341
    26,342
    Aug 18, 2007
    ~8600+' and loving it!
    Thanks to our current legal climate, you likely won't find a shop that will patch a steer tire. It used to done all the time before the lawyers got out of hand.
  7. Siinman
    Siinman Road Train Member
    5,158
    12,910
    Mar 5, 2017
    Kansas City, MO.
    Yes but most shops will not put it back on steer. It will now have to be a spare, trailer, or drive tire for them to mess with it.
  8. Concorde
    Concorde Road Train Member
    4,345
    15,427
    Jun 29, 2016
    West Melbourne Florida
    I just went through this with my local TA. Small nail center of tread and tire went flat. TA wouldn’t patch it and put it on so they ended up patching it for me to keep as a spare “drive tire”.
    Not that I wanted to roll with a patched steer anyway. Unfortunately though, the tire only had 55k miles on it and the exact replacement was north of $1,400. That included the 30 mile trip to my storage yard for the road call repair.
  9. Dadetrucking305
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    I should have worded the title different.It should been should I patch a steer tire.I would be the one doing the patch and running it till tomorrow when the tire shops open up but in that time I can run anywhere from 2-3 more Frac sand loads.But needing opinions of people with experience with this kind of thing to see if it’s something that could potentially come undone or it’s not as bad as some people make it out to be.
  10. SmallPackage
    5,274
    16,448
    Dec 20, 2019
    Marion Texas
    Done right with an RMA approved drill and fill stem and patch technique in tread within 1/2 inch of shoulders and you will have no issues. For steers you don’t want more then 3 patches total and only one per 90degree quadrant.
  11. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    390
    1,713
    Jun 22, 2022
    Weigh the profit vs risk.
    Would you make enough on those loads to justify running it, the risk being blowout, whatever road scenario that may be, plus service truck or wrecker when it happens.
