Can a non CDL class C licensee drive a non combination class 8 vehicle (bobtail)?
Discussion in 'Questions From New Drivers' started by Labrador, Oct 3, 2018.
  1. Labrador
    Labrador Medium Load Member
    485
    536
    May 31, 2018
    Can a non CDL class C licensee drive a non combination class 8 vehicle (bobtail) on public roads in the US?
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    No , it's a commercial vehicle.
  4. Labrador
    485
    536
    May 31, 2018
    Ok. I thought maybe without the trailer it would be ok. I should just look it up in the handbook.
  5. Moose1958
    Moose1958 Road Train Member
    15,088
    33,170
    Dec 17, 2010
    Williesburg, Virignia
    Depends on where you are and if this vehicle is a farm vehicle or not. Your question as asked can not be answered. Assuming you are NOT talking about a farm vehicle used intrastate NO it can not be driven with a class "C" license because by definition most class 8 CMVs require a CDL (over 26,001 rated weight).
    Call_Me_The_Breeze Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I say no. The gross weight is well above 26001, thus Class B and A territory (With any trailer making a combination)
    There was a time long ago Bobtails were treated almost as ordinary cars, but I believe that's been cut out of current rules.
  7. Call_Me_The_Breeze
    Call_Me_The_Breeze Medium Load Member
    504
    441
    Dec 30, 2015
    Not sure if this varies from state to state, but the way I understand it, a non-commercial license is a Class D, though most do not display it as such. So, if you hold a Class C, that *IS* in fact, a CDL, of which there are three classes...
    A) Combination vehicle 26,0001+ and/or towing 10,001+
    B) Single vehicle 26,001+ and/or towing under 10,001
    C) Single vehicle under 26,001 seating 16+ passengers, and/or HAZMAT requiring placards
    But in answer to your question, a Class C CDL holder cannot legally operate a Class 8 tractor, as it is a CMV capable of grossing over 26,000 lbs. Class A only. I guess technically a Class B holder could drive it bobtail, but I wouldn't risk it, as these are capable of grossing anywhere from 33,000 - 80,000 or more. And believe me, you don't want the kind of trouble that comes with operating a CMV out of your class certification. ESPECIALLY if your Class C has no air brake endorsement. Farm vehicles are exempt, of course, but I believe there are restrictions to the radius in which they can operate, as this also exempts them from IFTA, if I'm not mistaken.
    x1Heavy Thanks this.
  8. Ridgeline
    22,098
    113,135
    What is wrong with you, you got your answer.
    The truck is a commercial vehicle, with a GVW over 26,001 lbs which means you could drive it with a class B but not a class C license.
    The only way you can drive it with a class C is to have it titled as a private vehicle and if you do, you may be paying full sales tax on it.
    buddyd157 Thanks this.
  9. Chinatown
    Chinatown Road Train Member
    73,227
    164,410
    Aug 28, 2011
    Henderson, NV & Orient
    What if it's classified as an RV?
  10. Moose1958
    15,088
    33,170
    Dec 17, 2010
    I think you can drive it. However I have not looked into it. I just know that "commercial" use is used in a lot of the definitions.
  11. Chinatown
    73,227
    164,410
    Aug 28, 2011
    I've seen elderly couples driving Class 8 trucks as RV's. If I remember correctly, the 5th wheel had been removed. Some have another type hitch for an RV trailer.
