Can a crankcase breather filter on a 2013 DD15 be cleaned, instead of buying new one?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cicko, Apr 17, 2019.
  1. Cicko
    Cicko Bobtail Member
    I saw leaking at the bottom of crankcase breather filter, and it turned out it was cilinder kit failure, not a crankcase breather filter problem. Since i first bought a new one, instaled it, and problem continued, in the meantime i figured out what the problem was, i guess filter is filled with oil, same as the old one. Can any one of them be washed with brake cleaner, or diesel, or anything else? I managed to open it, and to get to the actual filter inside, it is not in bad shape, but it is "stuffed" with oil. Will it work good, if i just wash out the actual filter?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    there is no filter(media) in that device. Its a centrifuge , something like turbo. The oil pressure spins it and separates oil from air..
    Wannabe tech and 062 Thank this.
