California tandem law
Discussion in 'Questions From New Drivers' started by kbar909, Oct 9, 2013.
  1. kbar909
    kbar909 Light Load Member
    I know that my lovely home state of California is not very trucker friendly. So with the tandem law in mind I have this question.......Say you pick up a load that is headed to CA. It is a bit on the heavy on the trailer tandems so you slide your tandems to the rear to make it legal. You stop before you hit the state line and slide the tandems to the 40ft mark and proceed on your way. Once inside CA you get pulled into a scale and get popped for being heavy on the tandems. when you picked up the load it was a bit heavy on the trailer tandems and you needed to have your tandems pushed to the rear but now that you are in CA you need to have them pushed forward to the 40ft mark, thus that will make you over on your tandems. I dont get it....CA wants every trailer tandem at the same lenght, but every load is different and that will make every tractor and trailer show different on the scales. isnt the point of having movable tandems, a way of balancing the load? How would it be balanced if every trailer has a limit to where they can be? Is there special "CA" loads that are lightwieght so the driver can run the 40ft rule and still be weight legal? I would not doubt that CA has some kind of law that states that loads can on weight so much.California is nuts in my opinion. I will leave all political reasons out of this post but i will say that Im sure the rest of this great nation laughs at the Golden state for all of its silly groundbreaking laws we have. I know alot of you drivers either will not or dont look forward to driving in this state. This may be a stupid question to many of you out there, but being a total newbie (barely about to start training) this question has made me wonder for some time now. Thanks ahead of time for any input that can be provided!
    blairandgretchen and DoneYourWay Thank this.
  3. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    You load the trailer so it will be legal in every state you drive through.
  4. kbar909
    Ok I see. If you know you are going into CA then you should make sure it is loaded in a way that you will be legal with your tandems set a 40ft? I know its a pain to have the load reloaded and if the shipper does not have a scale on site then you will have to go to the nearest CAT scale to see what your weight is with the tandems set a 40ft. I assume if its not legal weight then you have to go back to the shipper to have them reload it?
  5. Florida Playboy
    Florida Playboy Road Train Member
    4,102
    6,621
    Dec 19, 2012
    Florida
    On your standard 53 footer how many holes from the front can you be to be within the CA limits?
  6. kbar909
    would you have them load it with as much weight as possible on the nose of the trailer, toward the rear or have them split or stagger the load? then if needed you can slide your 5th wheel if you are heavy on the drives? Or am I thinking too much into this?
    blairandgretchen Thanks this.
  7. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    40' kingpin to last axle. It can also be less than that.
    And yes, California is nuts.
    kbar909 Thanks this.
  8. Bucktrucker
    Bucktrucker Medium Load Member
    453
    148
    Dec 10, 2008
    ON THE ROAD SOMEWHERE
    i will say its cheaper to be over on axle than to be over the bridge law. Usually about the fourth hole or forward
    DoneYourWay Thanks this.
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    pulling a 53 step deck with a spread axle. i can say that shippers hate closed axle states. not many can load a trailer that makes the rears legal.
    the last load i hauled OUTTA CA. was reloaded 4 times. that was an all day venture going back and forth to truck stop scale. imagine wasting your entire clock getting loaded legally. and having to spend ANOTHER night in that messed up state once your finally ready to roll but have no hours to drive.
    and what really sucked. is no scales enroute. but i'jm sure arizona would have said something if i were to roll through with axles spread and trailer heavy.
    glad i'm pulling a 48 now. no mo worries.
  10. markealy
    markealy Road Train Member
    1,223
    1,300
    Jun 20, 2013
    EL PASO
    Or run around scale when you up load scale ahead for Cali make it to the 40 ft or shorter
  11. snowwy
    20,527
    13,262
    Jul 6, 2009
    sounds like he's a rookie. more then likely has one of them leashes that SCREAM at you for going out of route.
