I decided to do California hook up
Can you suggest best way to do it :
Should i just use T-coupler on tractor valve and run another 2 air lines to the back of the frame ?! Electric box ?!
I guess i need original location with air lines as well in case i switch trailer other day
California hook up suggestions
Discussion in 'Ask An Owner Operator' started by pavrom, Jan 11, 2023.
Run a T off your airlines and put shutoffs on your gladhands. Do the same on your trailer. Having the shut off valves at the gladhands just makes it simple instead of having to flip a valve underneath somewhere.
For the electrical you can make a simple junction box to split and go to the deck plate up too and out to the back. -
Back to topic.
Learned something new. Subscribed.Flat Earth Trucker and Siinman Thank this. -
Sirscrapntruckalot Thanks this.
