CAC effects on mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ChicagoJohn, Feb 9, 2017.
  1. ChicagoJohn
    ChicagoJohn Road Train Member
    2,387
    2,749
    Jan 14, 2016
    Chicago
    Last week I had a dyno done on the truck. It came back fine on hp & blow by, but the truck was only making 18 lbs of boost. I thought it might be the VGT, but we also pressure tested the CAC & hose to the turbo. Sure enough the hose had a massive leak and we also found a leak coming from the actual CAC. I had the hose replaced, but wasn't able to replace the CAC because if time constants and having to remove the radiator. I noticed my mpg went up a little just changing the hose, but will a leaking CAC cause additional loss of mpg's?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yes it sure will. How much depends on how much its leaking. I know it dont take a whole lot to make a diffrence thou.
    Also , not sure what truck you got but generally the cac is in front of your rad so shouldn't have to remove the radiator.
    ChicagoJohn Thanks this.
  4. ChicagoJohn
    2,387
    2,749
    Jan 14, 2016
    Chicago
    It's leaking from one of the front seems. Enough that when you pressorize the system, you can feel the air coming out by the front bumper.
    I have a Mack and 2 of the mounts are blocked by the frame, so we actually need to lift the radiator up to unbolt it from the radiator, so we don't actually have to completely remove the radiator, just lift it up about 10-12 inches.
  5. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    Mack says a 5psi drop in 30 seconds at 30psi starting pressure calls for replacement. My Detroit wasn't leaking anywhere near that bad and I had a noticeable drop in fuel mileage.
  6. ChicagoJohn
    2,387
    2,749
    Jan 14, 2016
    Chicago
    When we tested both the CAC & hose it was completely draining 40 psi in 10 secs. I don't know what the drop is on CAC only, but I know it's more then 5 psi in 30 sec. I'm having it done next Tuesday, so we'll see if I finally fixed my low mpg problem.
  7. LoJackDatHo
    LoJackDatHo Medium Load Member
    446
    752
    Jan 26, 2017
    Also a leaking CAC can cause truck to run hot. On a pull you'll be dumping more fuel then air, causing engine temps to climb. You may not notice it so much in the winter, but when weather starts to warm up, you'll notice it. I put in a new CAC, wasn't a year later truck started running hot. Changed thermostats, radiator, all cooling lines, new AC condenser, the whole works. Being as CAC wasn't very old, never thought about it running hot bc of that. Sure enough, it was the CAC. Put in new one and now engine fan hardly kicks on when weather is warm. Winter time, forget it. Gotta run winter front now.
    By the way, all the other things I changed chasing overheating problem were needing changed soon anyway, so I didn't feel like it was a waste of time and money.
  8. ChicagoJohn
    2,387
    2,749
    Jan 14, 2016
    Chicago
    I hope your right!!!! I've been chasing this problem for 8 months. Oil temps keep running hotter then they should be. It's not so bad in the winter, but when it gets over 70 out my oil temps are way hotter then they should be.
  9. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    Fix that CAC it will cost u a turbo...
    ExOTR and ChicagoJohn Thank this.
  10. ChicagoJohn
    2,387
    2,749
    Jan 14, 2016
    Chicago
    Update, truck went into shop today to have the CAC replaced and the VGT inspected. I'm leaving out tomorrow to do my regular run from Chicago to st Louis. Hopefully it'll start running better and the mpg's come up some more. I've come up about .4-.6 mpg from just changing the hose & clamp and that was driving loaded both ways through TN. (Eagle pass and the gorge)
  11. ChicagoJohn
    2,387
    2,749
    Jan 14, 2016
    Chicago
    Another update. CAC and house to turbo was done. Tasted the VGT and had full range and it's still getting bad fuel millage, (although it did come up about .5 mpg, so not all bad) so.............. I'm getting the ecm reprogrammed next week. We're convinced the guy who programmed my ecm when I had my dpf issues, just deleted about everything he could and set the turbo to a fixed setting.
