cac cleaning solvent and process!!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rah1277, Jun 30, 2020.
  1. rah1277
    rah1277 Bobtail Member
    Can someone lead me in the right direction on what to use and how to properly clean my CAC after a blown turbo on an ISX-15 cummins??????
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Take it to a HD radiator shop.
    062 and AModelCat Thank this.
  4. 062
    062 Road Train Member
    6,272
    33,777
    Oct 20, 2013
    Depends on how much oil is in it. I only had about a cup of oil come out of it. I used dawn soap and let it sit a couple hours, then rinsed with it tilted to one side and then tilted the other way and rinse again. I let it dry overnight and used a leaf blower to finish up.
    spsauerland Thanks this.
  5. w9l
    w9l Medium Load Member
    316
    514
    Oct 12, 2013
    What part of the turbo came apart? If the cold side impeller disintegrated that can send minute pieces of shrapnel in there and imbed it into the strangest places only to work through later causing another wreck. We usually end up replacing cac if turbo has catastrophic failure.
