Cabin air filter location?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Treefork, Feb 19, 2012.
  1. Treefork
    Treefork Road Train Member
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Where the heck is my cab air filter located on this 2007 Freightliner Columbia?
  3. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    under hood pass side between firewall and engine air filter canister.
    Treefork Thanks this.
  4. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    That was easy thanks. :)
  5. mrbmg
    mrbmg Bobtail Member
    38
    14
    Aug 6, 2010
    What part or where to get filter under bunk? Is it the same one that is for cabin?
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    The filter under the bunk is accessed by the side door or by lifting the bunk. On the passenger side you will see the HVAC housing. At the bottom of it (IIRC) there is a slide out filter.
    Martin
    mrbmg Thanks this.
  7. mrbmg
    38
    14
    Aug 6, 2010
    I know where it is but is it the same one as the hvac in the front?
  8. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Doubtful. Most of the trucks I've dealt with have used different filters for the cabin and bunk. It'd just be too convenient for the driver/maintenance techs/parts manager, for the manufacturer to use the same part, or standardize parts along a product line.
    mrbmg and gpsman Thank this.
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    The bunk heater filter is a different style than the cab filter on the firewall. To add even more to this, there is a second heater filter under the dash. It is primarily for when air recirculation is set. It has a similar function as the bunk heater filter. The firewall cab filter only filters the outside air coming in. The other filters are for filtering cab and bunk interior air. So, there are a total of 3 different cab/heater filters on the Columbia.
    mrbmg Thanks this.
  10. Julieo
    Julieo Bobtail Member
    I found and replaced the firewall filter and the one under the bunk. But is there one under the dash for the heater and air recirculation and how do I get to it
