CA clean idle
Discussion in 'Trucking Industry Regulations' started by Tama Mai Hawaii Nei, Sep 13, 2013.
  1. Tama Mai Hawaii Nei
    Tama Mai Hawaii Nei Light Load Member
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    I was doing some research on this and it seems that the way USDOT verifies wether or not your truck meets the carb laws in a clean idle sticker on the side of your truck. So I did another search and found you can purchase this sticker online. So why are drivers paying 1000s if all they need to do is order this 20.00 sticker and keep trucking. Even with a roadside inspection I highly doubt they are going to measure the exhaust coming out of your truck. If you have the prepass for scales you will have even less to worry about because chances are you will hardly get pulled in.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    there's a little box under the truck. it's called a catalyst filter. and it ties into the exhaust.
    that box makes it clean air certified. all they gotta do is cxrawl under and look.
    there's also the VIN of your truck.
    you can't fool DOT.
    i also heard that they have sensors for your exhaust. so if you took out the filter. they'd know. no need to stick a sniffer down your pipe.
    don't know if it's true. but anything is possible.
    i know colorado has sensors on the highway in denver. it senses your car driving with the check engine light on. you get a fix it ticket. i've seen one van hanging around.
    there's been talks of newer cars having ecms that can relay that information to road sensors. there would no be the standard emissions test.
    Tama Mai Hawaii Nei Thanks this.
  4. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    I read a story in Landline magazine awhile back. It said that CARB was measuring emissions from Reefer units at truck stops. Not sure how accurate it all was but if they're willing to do this the sticker plan won't fool them for long. I'm glad you researched though, I thought about the sane thing!
  5. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    I think I will put a smiley face sticker on my truck. Then the dot/carb guys will be so happy they will just give me a clean inspection and a cvsa sticker for my windshield.
  6. D.Tibbitt
    141,128
    no fooling the DOT. cant hustle the hustlers
  7. Tama Mai Hawaii Nei
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    I think this is a way the unions and mega carriers are trying to control the industry and weed out the small guy. They know the average owner operator can't afford a new truck or a $10,000 filter and this is a way to target them without actually being in plain sight.
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The sticker will need to have the barcode that matches your truck. Look closely at one next time.
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    I fixed my carb issue............ I quit going to comifornia!!
    Hammer166 Thanks this.
  10. snowwy
    20,527
    13,262
    Jul 6, 2009
    never noticed the barcode.
    wonder if that sticker is an emissions requirement. so if the hood got replaced for whateer reason. it would have to get a new sticker.
    if a car got a new hood. they didn't come with the sticker. but they didn't have barcodes either.
  11. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I don't think the sticker is required, just helpful for the Commie Arsehole Redtape Board to easily identify who can idle and who must suffer.
    AFAIK the only other state that uses the sticker as indicating the truck is exempt from their idling restrictions is Pennsylvania.
