CA axle group permit weight limits ???
Discussion in 'Heavy Haul Trucking Forum' started by GeorgeB, Aug 22, 2018.
  1. GeorgeB
    GeorgeB Light Load Member
    90
    8
    Feb 20, 2012
    Denver CO
    Hey guys,
    Can someone explain me what can you permit in F....State of CA for RGN loads, everything Im reading on their websites is so freakn confusing.... Lets say I have 3 axle RGN and 4 axle truck, what kind of weight can I permit on tridem axle group and is this type of trailer even permitted being over 40' from king pin to the last axle ? Please advice....
    Safe roads to you all !
  3. Rontonio
    Rontonio Road Train Member
    6,248
    45,378
    Aug 9, 2009
    You are going to need to comply with CA requirements for your 4 axle truck and have it inspected in order to obtain an overweight permit in California. When they do the inspection and you pass, they will issue you an inspection report with a number. On that report it will list your axle spacings for truck and trailer and list weights for green and purple weight roads. Typical purple weights will be 20k single 46725 tandem 59000 or 60000 depending on axle spacing.
    To certify your truck it has to level on a single valve, cannot be adjustable(no regulator), not liftae from inside the truck and must equalize to within 10% plus it minus with the other axles in the group. It must have 4 tires - generally or they will cut you down to only green weight (51-54k on a tridem).
    You will likely need to permit your empty trailer to get your load or permit your empty trailer out of the state after you unload - it will not meet the KP to rear axle length restrictions.
    You will not be able to run a tight 4 axle group or an east coast 3+1, so don’t even think about loads that weigh much over 80k.
    You should be a lot more concerned with how you get through Arizona to California as a 7 axle.
    truckdad, brian991219, Oxbow and 3 others Thank this.
  4. Rontonio
    6,248
    45,378
    Aug 9, 2009
    Oh - your truck also needs to be CARB compliant
    Those are the rules
  5. GeorgeB
    90
    8
    Feb 20, 2012
    Denver CO
    Great, so question on that.... That certification is a one time thing to be done ? to be able to obtain permits in a future?
    And I haven't gotten to Arizona yet, whats the issue with that state ?
  6. shmyreal
    shmyreal Bobtail Member
    43
    19
    Mar 12, 2017
    The main issue is how much weight you can get. You can get Class C Tridem Permit that will allow 59168 on 9' and 60000 on 10' axle spacing. Class C Tridem Permit is limited to I-10 I-19 I-40 US-93 from Nevada state line to I-40. BTW try google, it knows all...
    brian991219 Thanks this.
  7. Rontonio
    6,248
    45,378
    Aug 9, 2009
    And you overall gross weight must be under 140k
    brian991219 and Oxbow Thank this.
  8. bacoman
    bacoman Bobtail Member
    27
    57
    Sep 5, 2017
    With a 4 axle tractor you will need an inspection for each permitted load.
  9. SeboATS
    SeboATS Bobtail Member
    Hi, Im sorry for opening old tread. Do you need an inspection with 4 axle tractor for legal (80k gross) weights too? What about tridem trailer?
    Thanks
