C15 valve lashings...AGAIN?!?!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DocHoof, Sep 19, 2015.
  1. DocHoof
    DocHoof Light Load Member
    160
    81
    Sep 2, 2014
    Did my valve lashing on a Cat C15 a couple weeks ago. Set the intake to 0.015", exhaust to 0.03" and drove off into the sunset. However, something was wrong in toontown. At lower RPM (1200-1400), the motor clattered and knocked as well as idled rough and had what sounded like an exhaust leak "tick" at idle. Fuel mileage went from 6.5 to low 5.0 and pulling power was a joke for a 500+ hp tuned motor. So, I popped the valve covers back off and rechecked using the "go/no-go" style feeler guages. All were exactly where they were supposed to be. Ran a full gallon of Lucas injector cleaner through, as well as verified injector height; all +/- 0.005 to specs. Visually, everything looked good in the overhead and oil was getting everywhere its supposed to adequately.
    Ran the truck another 500ish miles. The noise was pi$$ing me off, so I ran the valve check yet again and according to my Matco feeler gauges, were where they are supposed to be. I then tightened the valves down so that the valve bridge would still wiggle, but not lift up off the valve spring like they do when set to specs. Lo and behold! The rough idle is gone, ticking at idle is gone, fuel mileage back in mid to upper 6's and can pull the world sideways again! Anyone ever hear of this type of thing? If so, what was the verdict?
  3. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    exhaust is set at 30 not 3 thous did you adjust the jake slave adjustments?
  5. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    another theory maybe you didn't adjust the right valve lash in the right sequence when you did it.
    062 Thanks this.
  6. lots of character
    1,031
    1,814
    Aug 12, 2015
    No, exhaust should be .76mm or .030"
  7. 062
    062 Road Train Member
    6,143
    33,166
    Oct 20, 2013
    Is this a acert?
  8. DocHoof
    160
    81
    Sep 2, 2014
    Yes, although I don't remember the spec I used. Jakes were never in question; always worked the way they should. Numerous posts on different forums all say 0.030" on exhaust and 0.0150" on intakes, so that's what I went with. In hind sight, 0.003" is about where they are now, although today I am going to be "adding a 0" to the specs I found and trying 0.003" and 0.0015" respectively.
  9. DocHoof
    160
    81
    Sep 2, 2014
    Not an acert. Its a pre-emmission kitty cat.
  10. DocHoof
    160
    81
    Sep 2, 2014
    Here is the order I did things originally:
    1. Valve lashings
    2. Jake slaves
    3. Injector heights.
    4. Double check all of the above.
    5. Triple check valves.
    And that's where I saw all the problems with 0.030" and 0.0150". Once I went tighter on the valves, all my problems and obscene noises went away and the thing runs like it should.
    Ttimefr Thanks this.
  11. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    a-cert and e-model and c-15 all set at same valve lash. if you didn't adjust the jake if I read your post right that maybe the problem. should adjust all at the same time.
