C15 oil pan bolt torque
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Loaderlou, Aug 24, 2020.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    130
    Feb 24, 2014
    Hi all. Can anyone tell me what the oil pan bolt specs are for a C15 6NZ. I’ve seen specs from fellow drivers or mechanics that range from 35 lbs to 53lbs. I would appreciate an accurate cat spec if anyone knows. Thanks
  3. Loaderlou
    342
    130
    Feb 24, 2014
    Thanks SP. I just replaced the gasket, pan, and isolators. I have a couple of bolts still dripping. I tightened them to 35 lbs. initially. Should I push it to 40lbs?
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Did you put beads of RTV @ the 4 corner T joints?
    pushbroom and Goodysnap Thank this.
  5. Loaderlou
    342
    130
    Feb 24, 2014
    No I didn’t. I cleaned the block and went up as evenly as I could. When I get a chance I’ll drop it again and do that. Thanks
  6. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    pushbroom Thanks this.
  7. Loaderlou
    342
    130
    Feb 24, 2014
    Thanks SP. I did see that when I took the old pan down. Thanks for all your help. I’ll let you know how I make out. Give me a couple of days. Thanks again
    spsauerland Thanks this.
