C15 oil capacity
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Aug 4, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    I just bought a 2002 9400i with a c15 cat. I am not to familiar with Cat engines. i was wondering if someone could tell me the motor oil capacity of this engine. Thanks
  3. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Had an 09' Prostar with a C15. Never had to put oil in it, but I think they can hold 4-5 gallons? Find out if your truck is one of the ones that returns used oil to the tank. Like mine was. Man I miss that truck...
  4. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Most likely it hold 11 gal. Some maybe 7.5 with a little sump. But most are around 10-11
    Cetane+ Thanks this.
  5. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    My 3406e (which should have same oil capacity as c15) takes 10 gal.
    silver dollar Thanks this.
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    40 qts for a single turbo,41 qts for acert.
    W903B and silver dollar Thank this.
  8. silver dollar
    481
    210
    Jan 31, 2009
    Thanks everyone. I guess I should have given the reason for asking this. I just bought this truck. On the dip stick there are no markings only a notch. Where it stands now, I don't if it is full or low. So I figured when I change the oil I could calibrate the stick. Thanks for all the input.
  9. rollin coal
    rollin coal Road Train Member
    13,077
    25,826
    Mar 29, 2008
    TN
    Depends on what kind of oil pan you have. Most likely 10 or 11 gallons.
  10. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    It is a 6NZ C-15 and requires 10 gallons of oil to fill to capacity with a filter change. The low side of the calibration of the stick will be 1.5 gallons below the full mark.
    maconhadalata, W903B and silver dollar Thank this.
  11. dieselmecnic
    dieselmecnic Bobtail Member
    5
    5
    Aug 5, 2012
    Dip stick calibration procedure:
    Drain all the oil from engine. Including the the front section of the oil pan. install 8 gallons of oil in the pan. At this point. Mark the "add oil" mark on the dip stick. Now. Install one more gallon in the pan. Mark the "full line" on the dip stick. Install one more gallon. ( This is for the oil filter ). Install oil filter dry. ( The engine oil pump puts out so much volume, the engine will not be harmed for this calibration procedure). That will add up to 10 gallons. This is for a standard oil pan on a 3406. Hope this helps.
    JimmyWells, hiredgun and silver dollar Thank this.
