C15 mbn valve lash and jake lash specs?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Muddydog79, Dec 19, 2020.
  1. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    I know 30, and 15 thousandths for exhaust and intake, are jakes 33 or 37? And i saw in a previous thread an op said he seated the valves with a dead blow? Is that really necessary if you rotate the engine to tdc in the direction it naturally rotates?
  3. Muddydog79
    820
    2,147
    Apr 14, 2016
    Also what are the torque specs on the valves/injectors/jakes?
  4. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    From memory >IVA is .020 and CAT brakes were .027. Always back off IVA and jakes and set valves first.
    Always tight getting anything in there to torque, I always freehand the torque and mark when done.
    I made a crooked face on the deadblow comment too.....never heard of it.
    Floor Jack, Muddydog79 and AModelCat Thank this.
  5. AModelCat
    161,251
    I don't understand how one can "seat" a valve by hitting it downward?
    Muddydog79 Thanks this.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    I think its the “snap back” that seats it not the hit. I worked for cat for a while in the early 2000’s and I dont remember doing that.
  7. AModelCat
    161,251
    That'd really be no different than the valve simply closing as the cam rotates. Sure you're not going to get that little "snap" but really, if a valve spring with what, 50+ lbs of force can't hold the valve closed and seated, a valve set would be the least of your worries on that engine.
    Muddydog79 and Roberts450 Thank this.
  8. Muddydog79
    820
    2,147
    Apr 14, 2016
    .27? First ive heard of .27...
  9. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    Double check which brake you have. MBN1 and up Jacob 340D says .030 in. +/-.003. Brake Nut torque is 25ftlbs +/- 4
    I was probably thinking bxs, mxs, most have CAT brakes and are .027
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I never tap with mallet either to seat everything. I do run adjusting screw tight a couple times to seat everything before inserting feeler gauge and making adjustment.
    Roberts450, Muddydog79 and Goodysnap Thank this.
