Hey truckers, I have a 2007 kw w900 with a nxs c15 model. I didn’t start the truck over the weekend and Monday I tried to start it it cranked for about 15 seconds than stopped it felt like the batteries died even though I bought them new. Now it cranks one time than locks and sounds very very heavy trying to turn over but doesn’t. I removed the alternator belt and turned over the fly wheel thinking maybe the pistons were stuck but still no luck. Can it be the starter . Any thoughts? Thank you.
C15 engine won’t turn over
Discussion in 'Ask An Owner Operator' started by Moephilly1, Feb 1, 2022.
Page 1 of 3
Moephilly1 Thanks this.
Jump the solenoid on the starter ... it will probably fire right up.
I have the same issue every once in a while for the past few years. Gives a dead key that sounds like it is hydrolocked. I think it is the starter relay. I havent replaced mine because if I cycle the key a couple times it will usually turn over. AND I havent found an aftermarket non KW relay ... and they want like 300 bucks for something that should be 20 dollars. Non start for me happens a lot when the batteries are getting weak ... maybe you have a loose connection on your new batteries.Moephilly1 Thanks this. -
77fib77 Thanks this.
The gear reduction starters are nice! I like my mitsubishi ... think its been in there around 4 years now. FYI, new starter made no difference for my dead key problems.
77fib77 Thanks this. -
Slow crank sounds like you've got a bad battery out of the new set
p608 Thanks this.
Page 1 of 3
