C15 - coolant hose
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Feb 19, 2018.
  1. rollin coal
    rollin coal Road Train Member
    13,083
    25,876
    Mar 29, 2008
    TN
    Single turbo if it matters. Does anybody know offhand what size ID/OD coolant hose that short piece between the thermostat housing and water pump?
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,225
    70,373
    Dec 9, 2011
    South west Missouri
    Sometimes if it’s not worn off, it’ll be printed on the hose.
    rollin coal Thanks this.
  4. rollin coal
    13,083
    25,876
    Mar 29, 2008
    TN
    I don't have it off yet but no luck with that on what I wiped off and could see. It's only about 2" long so might not be on there. When I get it off I can tell I just wondered if anyone knew offhand.
  5. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    It is 1 1/2 I.D. and little over 3 inches long.
    Oxbow and rollin coal Thank this.
  6. AModelCat
    154,360
    And probably $80 from Cat lol.
    Oxbow and Goodysnap Thank this.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Might as well get a t-stats gasket as well or pump plate o-ring. Need to take one or the other off to remove and install properly.
    Oxbow, spsauerland and SAR Thank this.
  8. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    Well, of course!
    Oxbow Thanks this.
  9. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    Yup its in a tight spot so one or the other has to come apart. If he does t-stat gasket, probably wouldn't hurt to install t-stats while your already there.
    Oxbow and spsauerland Thank this.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    9Y-4104. Around nine bucks from Cat.
    SAR, Oxbow and rollin coal Thank this.
  11. rollin coal
    13,083
    25,876
    Mar 29, 2008
    TN
    Yeah changing t-stats also. Found some reasonably priced flexfab hose at anythingtruck.com
    SAR Thanks this.
