C15 code 94
Discussion in 'Ask An Owner Operator' started by Moephilly1, Nov 12, 2018.
  1. Moephilly1
    Moephilly1 Light Load Member
    111
    35
    Oct 6, 2016
    hi truckers I recently bout a 07 W900 I started driving it today and the check engine light came on with code 94 any thoughts thank you
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Code 94 is IVA # 5 and 6 that is not responding, current is too high or low.
    Most of the time the plugs going to the solenoids get brittle and loose contact, or could be a broken wire. I would remove the rear valve cover and check the wiring harness or plugs going to the IVA's.
    CAT does sell new and improved plug ends you could install if that is the case.
    pushbroom Thanks this.
  4. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    I'm assuming this is a acert twin turbo?
  5. Moephilly1
    111
    35
    Oct 6, 2016
    Thanks I appreciate it
  6. Moephilly1
    111
    35
    Oct 6, 2016
    Yes it is I have to check ASAP because I’m losing power I believe that may be the problem
  7. frustrated trucker
    frustrated trucker Bobtail Member
    6
    I'm having the same problem is it too hard to change the wire harness to the actuators
