C15 acert injectors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dapper Dan, Apr 15, 2016.
put a set of 58's in it
10r8502 an older none epa injector
Older injectors do not match the acert piston, the 625hp engines use a larger injector, that is what you want to upgrade with.
OK so get injectors for a 625 acert is what I need to do here.
That would be my suggestion if you think that is the route you want to go, a good aftermarket tune would likely accomplish more and be similar in cost even with paying to have the IVAs disabled.
Thank you for the info very much appreciated.
