Hi everyone
Planning to overhaul my C15 accert (NXS) , I am shopping for the kit and I heard CAT oem is not good quality anymore.
What you guys say about:
Interstate McBee, PDI, federal mogul.
Also , does anyone know good CAT mechanic around Milwaukee?
Thanks
C15 accert, overhaul time? Help plz
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jb88, Oct 5, 2021.
I wouldnt hesitate to use a genuine CAT kit. Back in my prime, I would average around 50-55 hrs maybe 60 for a full in-frame Platinum kit with compound turbos. I think this timeline is fair condition depending, and chassis depending. Block machining would not be included in this. Usually clean up and epoxy the liner o-ring flange.
Oxbow, black_dog106 and pushbroom Thank this. -
IPD is pretty popular these days. They are doing lots of different and cool things. I used IPD and so far so good.
black_dog106 and Oxbow Thank this. -
Did you use their platinum kit? And how many miles after overhaul?
I have a 6nz and used their one piece steel pistons. Did liners, pistons, rings and all bearings. Did use a cat headgasket.
On your accert I would seriously consider using their 16:1 compression kits and removing the IVAs and re-tuning. But I'm not sure if the lower compression kits for an accert would have warranty. The one piece steel I used doesn't have a warranty. The stock kit would have.
I've only put maybe 150,000 miles on but they are hard miles. And more hours than miles. Plus 700hp -
Thanks -
2g oil burning
Head cracked ,. Fuel mileage is 4gpm
