I have an '07 Pete w/a c-13 acert. The engine code tells me the high coolant sensor is faulty. Where is it located? Can't seem to find any sensors in the head. Thanks
c13 acert coolant sensor location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bilson1, May 2, 2013.
its on the tsate housing u might have to take off alt or ac compresser to see and get to it
Thanks jameslawton. I found it underneath the thermostat housing, behind the accesories mounting plate. Needed to remove the fan hub to get to it.
You usually can get to it through a hole in the accessory mounting bracket if you take off the main belt. Removing the tensioner may help too. I never had to pull the fan hub, but you may have a different set up.
yeah i have never removed the fan hub to change one but always a first for everything and glad to know its working for u
Had to remove the fan to get into the hole in the bracket. If the fan was mounted lower, I may have been able to get to it. I couldn't get my hand in there to undo the plug. Maybe my hands are too big. LOL Thanks
yeah its all good as long as u got it changed dont make much diff how u did it still cheaper then paying $115 A hour for a shop to do it
