C12 - 430 HP or 480 HP
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CbarM, Jul 16, 2013.
  1. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    I have a 2000 T600 with a C12 (couldnt be happier) rated at 430 HP. While doing some online reading I saw that CAT offered this engine as an RV application in the rich guy style motorhome at 480 HP. Why would they offer it in an RV that might weigh 30K lbs n not a truck that might weigh 80K lbs??? How easy is it to boost it up from 430 to 480?
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    whats the torque at 480 hp, it may be less since an rv doesn't need as much.
  4. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    Im not sure on the TQ but mine is at 1650, and usually with higher HP you get higher TQ so I would say it would be 1650 or more...
  5. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
    Not all times would the torque be higher, eg marine applications
  6. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    Well Im pretty sure that an RV and marine engine would not be the same.
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I'm guessing that emissions has something to do with it also !
    Marine , rv and fire trucks get a free pass .......
  8. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Here are some standard ratings I have never seen a 480
    430 HP 1800/2100 2KS72000 - UP
    1650 PT
    455 HP 2100 2KS72000 - UP
    1550 PT
    EMERGENCY VEHICLE,RV AND BUS ONLY
    505 HP 2100 2KS72000 - UP
    1550 PT
    RV/FT
  9. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Would imagine a PDI tune & turbo via Mr Haney would be the ticket to increasing power. Look him up & see what he can do.
  10. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    I have a pdi tune and turbo'd c12 and all I gotta say for a 12l it pulls amazing. I can hang with c15s pretty easy. It sees about 43psi on a good pull. 80k isn't much of a struggle at all.
  11. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    WOW! That sounds pretty exciting to me! The one thing I am concerned about is this engine has 43000 hrs on it, no work done n not using oil yet. If I was to start juicin it up then would this drastically shorten the life of it? Dude6710 - have you dyno'ed yers since the upgrade?
