C-17 kit
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jacob-3408, Feb 15, 2022.
  1. Jacob-3408
    Jacob-3408 Bobtail Member
    8
    May 18, 2019
    So I’m doing a single turbo kit for my c-15 that had a platinum rebuild about 300,000 ago and the head cracked on me. I’m trying to decide if I should just run the original acert 18:1 pistons (they are still in good shape) with the actuators turned off or, switch to a stock c-15 bore 16:1 piston or what I would like to do is run the c-17 kit that IPD makes. My question Is does anyone have any experience with the c-17 kit as far as reliability is concerned.
    for the 18:1 pistons I’m just concerned I’ll have head gasket problems down the road with the actuators turned off but on a side note I’m going to run a fire ringed head and ARP head studs on the motor so could that be enough clamping force to overcome the cylinder pressure.
  3. pavrom
    pavrom Road Train Member
    3,191
    7,317
    Apr 29, 2012
    NE illinois
    Go to cat masters 3 on FB ...they should be able to help you out
  4. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Unless you want to make big power just go with the 16:1. And you could still make 700 easy.
    18:1 with no actuators some say head gasket will live if you drive it right, never lug it.
    dirthaller, Bean Jr. and Brettj3876 Thank this.
  5. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Pretty mixed bag of opinions..
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    18:1 turned up isn't gonna last long. Save yourself peace of mind and go 16:1
    Like @lester said if you go with 18:1 don't lug it. Even with studs that's a ton of cylinder pressure, asking for trouble down the road
  7. Diesel Dave
    9,214
    29,386
    Jan 20, 2010
    Hesperia, Ca.
    There’s a thread on here of a member (@Superhauler) I believe, that was about having the head machine with rings or something for his Accert. It eliminated the head gaskets issue for high compression pistons. Maybe some others can chime in on that. Btw, haven’t seen Superhauler on here for awhile.
    Bean Jr. Thanks this.
  8. AModelCat
    161,251
    Sadly he got the ban hammer.
  9. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    O-ring cut head. It's actually a stainless steel ring I think. I'm just about ready to have a new ring cut head thrown on my block. I'll snap some pics. Will definitely help head gasket hold if everything else is right and tight. Protrusion that is
    dirthaller and Diesel Dave Thank this.
  10. Cat sdp
    Cat sdp . .
    21,176
    75,006
    Apr 8, 2012
    Orion's Belt
    18:1 you need the actuators….. if you want to get rid of them go with the 16:1 pistons
  11. dirthaller
    dirthaller Road Train Member
    1,109
    12,963
    Sep 22, 2011
    Coloratah
    You’ll be fine. Leave it the way it is. Look up Adepe Ape on you tube. Points out what @lester is talking about with counterbore cuts and stainless shims. Use a Genuine Cat head gasket, make sure liner protrusion is within a half a thousandth all the way across the deck around 5 thousandths (IIRC), which is easy to obtain with the Cat recommended counterbore/stainless shims. Use the Cat water jacket sleeves. Make sure your spacer plate is perfect. Make sure your ECM isn’t tuned improperly (injection timing…not sloppy fuel) and keep an eye on your water temp. Lower compression pistons might give you a little more longevity and a little less heat if you’re pulling heavy steep grades.
