C-16 Reviews
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dustin15198, Nov 14, 2017.
  1. dustin15198
    dustin15198 Bobtail Member
    6
    I'm looking at a couple different trucks for some equiptment heavy hauling. We go up and down mountains sometimes and need some power. Looking to get a daycab pete. Im looking at a 2003 379 with a c-16 cat. Whats everyones reviews on it over a 6nz cat that were also looking at.
    Thanks in advance!!
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Unless your gross weight is going to be 100,000lbs + all the time, i'd go with the 6nz. A 6nz at 550hp/1950ft-lbs will do whatever a C16 will without destroying itself running cold. People i know with them are having the same problems as they used to have with the KTA600. Can't work them hard enough to keep them warmed up properly and the engines suffer from it.
    ladr Thanks this.
  4. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    More power. Just as reliable as the 6nz. Check to see if it also has the larger driveshaft and u-joints.
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    If they have temperature problems then they have deeper issues, a 16 is no where close to a K series for displacement, and should hold water temp no matter the load.
    wore out, snowman_w900, Oxbow and 2 others Thank this.
  6. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Got nothing to do with water temp. It's a low cylinder temp problem. Any big horse engine will suffer if it's not running under enough load to warm it up properly. My 3408 would run raw fuel down the back of the stacks if i couldnt keep 18-20psi of manifold on it. I had a fueled-up 1693 that was even worse.
  7. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    That is a mechanical, no comparison. I know people that work 1000+hp engines daily and not a single one of them had issues like you mention.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Simple..... c-16 hands down very good engine. Better tourqe than the 6nz.
    Lalito.1234, cke, wore out and 3 others Thank this.
  9. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Nope, nope,....and he'll no.
    cke, wore out, snowman_w900 and 2 others Thank this.
  10. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    I'm gotta disagree with this. A friend of mine has a factory 7cz 600 / 2050 and the only trouble he had was liners. Had the block done and 300,000 still going strong.
    We idle alot and have alot of pto time pumping off product and he's never had the issues you discribe. A c-16 is basically the same engine as a c-15 minus rotating assembly.
    Why would you say a 6nz dont have cylinder temp problems, but you say a 7cz does? How? they use basically the same compression ratio.
    cke, Oxbow, wore out and 1 other person Thank this.
  11. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Guess it must have been faulty liners.
