Buying used dryvan, is 10 years too old?
Discussion in 'Ask An Owner Operator' started by slow.rider, Oct 3, 2017.
  1. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    OK so I'm stepping up from a basic click-and-go loadboard to booking my own loads. Looks like I'm going to start off this level in dryvan even though most of my experience is reefer. Spend 6-12 months focusing on booking and lane analysis, then maybe step up to the extra difficulties of reefer once I've got a better handle on the system. Basically use the dryvan to get the experience and the money to buy the reefer.
    I've learned a lot about what to look for and what to avoid in terms of structural problems. But there's a big dropoff in price when you get to ten years age. I know some shippers demand trailers not more than 10 years old. So I guess the question is, let's assume I run the thing for a year. Am I better off getting the newer trailer, or saving close to 10 grand by getting an older one, and missing out on some of the more particular shippers? What's the approximate extra net I'd be missing out on in a year from owning a trailer that is more than 10 years old?
  3. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    not a dryvan but i have a trailer that is 31 years old. i just used it last week. its not the prettiest thing on the road. and i don't use it often anymore but its still solid keep it maintained it will pass a dot and works flawlessly.
    my newer trailers are about 11 years old. i don't pull dryvan but i have never had anyone ask me how old my trailers were
    i guess if its sound i wouldn't worry about a 10 year old trailer. check for rust in the frame, check for cracks around the suspension/load bearing members, floors solid roof s cams bushings breaks, air lines ect most everything that wears out on a trailer can be easily replaced as long as the bones are good. a re-decking of a dry van could be quite a project though.
    wore out and slow.rider Thank this.
  4. Chinatown
    Chinatown Road Train Member
    73,227
    164,408
    Aug 28, 2011
    Henderson, NV & Orient
    Some union outfits will check the data plate for the trailers age.
    Friend of mine bought a used trailer at a farm auction; 53 ft. dry van. It had been used for storage. Paid about $1500 for it. Once he cleaned the mildew off it looks great. Replaced the dry rotted tires with some decent used ones and hit the road. Has no problem booking loads or passing DOT inspections.
    Dave_in_AZ and slow.rider Thank this.
  5. nightgunner
    nightgunner Road Train Member
    2,112
    2,799
    Jul 23, 2013
    Cedar Rapids, IA
    I work with another owner operator who like Chinatown said has an older trailer his is a '99. He keeps looking spotless you would think was only two or three years old and according to him he never has a problem getting it loaded. I do open deck in my trailer is 10 years old and no one has ever asked me how old it is.
    slow.rider and Chinatown Thank this.
  6. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    I have. Typically, it is those shippers who are extremely concerned about cleanliness who demand new trailers. Empty aluminum can vendors worry about dirt getting in the cans before they are filled with drink and sealed. They can be sued into penury for that sort of thing. Paper vendors worry about water leaks. One rejected roll of paper can cost them anywhere from five to thirty grand, depending on the paper, not to mention an unfulfilled order.
    bzinger and slow.rider Thank this.
  7. slow.rider
    2,005
    4,740
    Apr 4, 2017
    NYC
    I'm finding a huge disparity in trailer prices in this area. Tons and tons of dryvans in the $5000-$9000 range, but they're all 2007 or older. It's nearly impossible to find a 2007 or older for over $9000. But if I limit the search to 2008 or newer, there is basically nothing under $18,000. The average selling price falls off a cliff when it hits 10 years old.
    This suggests that there may be significantly more money to be made with a less than 10 years old trailer. The other possibility is maybe there's some reason for large fleets to dump their trailers after 10 years, glutting the market. So if the cliff is due to an accounting practice such as a commonly used depreciation schedule or whatever, then I'll take a 2004 all day long. But if I'm disqualifying myself from some loads and thus leaving money on the table by doing that, then the question becomes "how much?"
  8. rollin coal
    rollin coal Road Train Member
    13,077
    25,826
    Mar 29, 2008
    TN
    You're not going to miss anything worthwhile get the cheaper trailer.
    RubyEagle, DSK333, wore out and 4 others Thank this.
  9. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    222
    501
    Feb 26, 2008
    **Deleted** wrong information.
  10. Antinomian
    2,076
    3,241
    Feb 17, 2013
    The only shippers I have had that insisted on new trailers were also the kind of shippers that mostly dealt with large carriers. Ever haul for Mead Paper? Rock Ten? How about empty cans for Crown Cork and Seal or Metal Container? I wouldn't spend ten grand for the possibility of one day getting a load from one of them.
    izifaddag and slow.rider Thank this.
  11. Dave_in_AZ
    369,690
    The only ones I've seen demand 10 years or newer are the giant paper rolls.
    Lot's of places will do a walk through and check for leaks both on the floor & roof.
    The giant paper rolls worry about the frame buckling.
    slow.rider Thanks this.
