Buying a truck for hauling frac sand
Discussion in 'Ask An Owner Operator' started by jpsands, Dec 9, 2011.
  1. jpsands
    jpsands Bobtail Member
    San Antonio, TX
    Hello everyone - I'm in the process of finding a truck to haul fracs and in south Texas. The truck will be pulling a pneumatic 1200 CF Hobbs trailer. I found a FREIGHTLINER COLUMBIA 120 with a Caterpillar C-12 380HP engine 3.90 ratio. Do you think this truck can do the job? Or what should I look for? Thanks in advance!!
  3. God's Kid
    God's Kid Bobtail Member
    9
    4
    Dec 11, 2011
    Parker
    Depends if your going to go off road. Consider the clearance of the vehicle. Aerodynamics are ok, but that's not what your looking for if you go off road. Power maybe ok. I think I would go with a little more HP than 380. Transmission would be another concern. Off road with a 13 or 15(with deep reduction), Rears: 3.70,3.90,4.11,4.33, 4.44, or if you can still get them 2 speed rears, ie: 3.70 highway/4.33 off road.
    Lepton1 Thanks this.
  4. God's Kid
    9
    4
    Dec 11, 2011
    Parker
    Almost forgot I have a friend that was going to do a similar operation in so. TX. He decided not to do it, because 1 of his friends had he's truck and trailer stolen. So trucker beware where you leave your truck or equipment at!!!!
  5. AC141
    AC141 Bobtail Member
    9
    Interesting - thanks for the note above ^
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Might want to check out some Western Star Trucks.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    C12 can be uprated to 430 im pretty sure. 430hp and 3.90 rears is plenty for flatland texas. We run isx12 425hp with 8ll. Not sure on the rears but with regular 22.5 were at 1900 rpm @65. With this setup i can be 70k plus and not drop a gear running i80 all the way across pa
    We run compressors not blowers. Gardner Denver's on heil aluminum cans
