Buying a Semi
Discussion in 'Ask An Owner Operator' started by Thotphobia, Jul 9, 2021.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Alright drivers, we’re trying to buy a semi currently, but we want to know the best setup for the type of work we do. We currently haul logs, weigh about 75k-85k, 24.5s in NC, barely any uphills or downhills, local driving. I barely get on interstate so I don’t go past 60 80 percent of the time. What y’all recommend on gear ratio, transmission etc? I see a whole bunch of 3.90s but I heard they ain’t as good as the 3.70s in pulling or am I wrong ? I know 13 and 18 speeds are the best. Thanks fellas!
    Vampire Thanks this.
  3. AModelCat
    154,360
    3.90 will get things rolling easier than 3.70.
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
  5. roundhouse
    roundhouse Road Train Member
    3,130
    7,033
    Jul 11, 2018
    Uhh, check with some other local log haulers ?
    To see what they are running.
    30 years ago the only tractors log haulers were R model Mack day cabs .
    But now you see long nose Pete’s with huge sleepers and all kinds of highway tractors pulling logs.
  6. Big Road Skateboard
    5,691
    29,648
    May 2, 2021
    3.90s and a ten would work on flatter ground, 13 or 18 for mountains.
    A 3.70 even would probably be fine for your application too, and give you longer legs on the highway.
    For your application, I wouldn't rule out either, and wouldn't rule out a good truck with a 10 since no hills. Look for the best truck first.
  7. OldeSkool
    OldeSkool Road Train Member
    1,645
    4,459
    Jul 17, 2018
    New Hampshire
    I used to haul logs in Arkansas. Mostly flat country. Many of the drivers liked a 13 speed but I always thought an 18 would be nice for granny low when pulling away from the loader in mud. Also full lockers would be really nice. Good ground clearance of course. About any truck works though if you need it to bad enough lol.
  8. OldeSkool
    1,645
    4,459
    Jul 17, 2018
    New Hampshire
    One thing to consider though is you get paid by the ton so keep it light as possible. For an overall money maker you won’t beat a day cab Freightliner Columbia with 10 speed tranny. Probably give you an extra 2 tons at least payload. I was lighter in a sleeper Freightliner Century than a day cab double framed Mack by about 4,000 pounds. He could have probably drove up a skidder trail though. Kinda just depends what you want.
  9. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    T800 or a western star are pretty much all that’s run off road for a reason, 44-46k rears and 4.10-4.30 with a 18 or even a bag of #### 8ll should work fine, 3.90 and 40s will probably be fine if you know how to drive and aren’t up to the axles in mud every load trying to take off
