Buying a RGN need opinion on what to look for.
Discussion in 'Heavy Haul Trucking Forum' started by Mad dog logistics llc, Sep 19, 2017.
  1. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    152
    37
    Jan 13, 2014
    I currently use a RGN from a guy we haul for but his equipment is scary and even though it has a safety sticker, when its loaded its a different story.
    Im looking for opinions on what kind to buy, what to look for ( like trailer with center beam good or bad) ( lift axle verse a flip axle) Im looking for 50ton+. What trailer will allow me load more types of equipment. We haul oversized and over dimensions. I have dump trucks and would be moving equipment for guys I haul currently haul for. Plus would like to start hauling out of state again.
    Beam verse flat deck
    Minimum deck size.
    Flip axle verse air lift.
    Rust issue what is ok and what something to walk away from
    Any other thing Im missing let me know, Im not looking for something new. 20,000-30,000
  3. heavyhaulershotcaller
    heavyhaulershotcaller Light Load Member
    97
    39
    Sep 1, 2017
    South Central U.S.
    Most versatile in my opinion is a flat deck. A beam is too much work for me although anyone with a beam trailer has my full respect because it is a lot more work with throwing cribbing around a lot.
    I assume you will be using a 4 axle truck. If running 7 axles I would say 24' well would work fine. You could get by with even less deck space then that, but you have to watch your inner bridge when permitting. If it is 8 axles (quad or 3+1) then typically a 26' works well for the fact of using the extra deck space to get your weight distribution correct.
    Finding a trailer of that caliber will be very rare to find a tandem with 3rd flip.
    Rust...check crossmembers first. If they are peeling off sheets of rust then there maybe a problem. Hit the crossmembers in different places with a hammer to see if it punctures through. They can be replaced, but could be rather costly.
    With a $30,000 limit that will probably not allow you to have a lot of choices to pick from. I'd say find something solid and run it a year or two and get your cashflow and credit built up and then upgrade. Be careful if going to auctions. Most trailers at auctions typically are someone's problem they want to pass off to someone else. I'd say stick with private sales or dealers. Both are hard to gauge if they are honest or not. If it is a trailer with fresh paint be careful when looking it over. Liquid overhauls typically are trying to hide something. Not always, but often.
    Mad dog logistics llc Thanks this.
  4. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    My plan was to look for a solid trailer that needed some work Paint Brakes ext. I have a shop to do all the work make some money and upgrade once the work starts to flow. Both my drivers have experience moving over sized and over dimensions. Thanks
  5. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    Thoughts on a flat with a raised beam
  6. heavyhaulershotcaller
    97
    39
    Sep 1, 2017
    South Central U.S.
    Some people call it a raised beam. I call it a dropside deck because the main beams are the same height as a flatdeck...its just the outer beams are shorter getting lower height with machinery excluding excavators. I say that because its not the cab your worried about on height, its the boom. So no benefit there for an excavator.
    Hauling small rollers or pavers, small dozers even may be a problem with a dropside, but if you are not hauling those things and find a good deal on a dropside then I'd say have at it. A dropside will tend to be a little heavier then its flatdeck counterpart.
  7. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    It will certainly bring the height of an excavator down, drop your machine 6" you drop your boom heal 6" which drops your overall height.
    Oxbow and Mad dog logistics llc Thank this.
  8. Rontonio
    Rontonio Road Train Member
    6,426
    47,251
    Aug 9, 2009
    Normally the center beams on a drop side will be taller than a standard flat deck.
    Oxbow Thanks this.
  9. heavyhaulershotcaller
    97
    39
    Sep 1, 2017
    South Central U.S.
    Technically true, but that typically falls mainly if you are talking about 65ton capacity and up. Looking at 50-55ton flat decks (he brought up 50ton+ 3axle) most center beams are 16" to 17" tall. That is typical height beams of a flat deck. Dropside decks' main beams are the same for the most part. I did come across a rare 55ton Trail King dropside deck recently though with 18" main beams.
  10. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    Is there a website where it gives you the rules for each state on Over sized and Over dimensions. Ive noticed in some states there are police escorts that block the on ramps and some states that with the same equipment dont have the same rules. The guy we haul for not has his Secretary gets permits just for local State and city roads when we haul his excavator.
  11. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    I pulled a Trailking drop side 55 ton, center rails were at 24" with 80,000 on the deck, the drop sides were at 18"
    Oxbow and johndeere4020 Thank this.
