Hello everyone, I am in the market for a used Peterbilt truck I found a 2006 378 Peterbilt with C15 475 hp the truck is great for the work I do. My curiosity is this truck was used mot of the time for logging, is anybody familiar with this kind of job? I would like to know what life was this truck expose to. Any comments welcome, thank you everyone.
Buying a Peterbilt that it was used for logging.
Discussion in 'Peterbilt Forum' started by ralin10, Jan 10, 2016.
Hi ralin, oh, be careful with an old "stick hauler". Those loads are always pretty heavy ( 50K or more) and that takes it's toll and on a 10 year old truck, that may not be the best idea.
ralin10 and chopper103in Thank this. -
The roads those trucks run on tend to beat the suspensions pretty bad.
ralin10 Thanks this. -
First off, that truck was intended for on highway use, and it was put to work as an off road truck. The weight and the conditions in which those trucks are used are extreme, even for trucks that get spec to do that work. If you want a rebuilder, then this could be a great project truck, but for a an everyday worker that will make your living, I would think long and hard about it. This truck has had a hard life and will need a lot of attention in the future. One of the things most people don't think of is the all the twisting a truck and it's frame does over the life of a truck. These trucks do so much twisting and bending loaded on rough roads, every bolt and rivet in the frame and everywhere else gets loose over time. Good luck on your decision.
You would be better off to avoid a prior logging or oilfield truck. Those things get beat pretty badly, and I am speaking from personal experience.
Hi ralin, I work in a similar industry hauling loads around 100k and occasionally going off road and it really depends on if the truck is spec'd right for the job. I've noticed the peterbilts/kenworths tend to hold up better in severe duty applications like off road heavy hauling applications. The way the frames are built tend to hold up better. A lot of other light duty trucks the frame bolts loosen up or crossmembers and frame tend to crack. How heavy are the axles and suspension rated for? Does it have a double frame? What type of transmission and axle ratio does it have? A lot also depends on how the truck was taken care of. Does the guys stuff seem pretty decent or is it all look like its been neglected?
rocky34 Thanks this.
