Burnt 3 compressor clutches
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Jun 18, 2016.
  1. truckerbangin
    truckerbangin Light Load Member
    262
    44
    Jan 22, 2013
    My t600 keeps burning up compressor clutches and coils. It'll run great for about a hour our so while driving then air will go hot (check under hood) ac clutch slipping or smoking. Truck had new compressor installed along with new drier last saturday.
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Tech should know wassup but:
    1. Gook parts ( clutch )
    2. Low or high voltage to clutch
    3. Bad bearings in comp or little to no oil /bad comp.
    If it were me ( especially on my nickel ) the comp , clutch and drier all have to go...again. If the issue is the comp she's sent shavings into the system which will take out your expansion valve eventually. Be sure to flush lol....
    I say unlikely you got 3 bad clutches, comp is bad / has issue. Also unlikely it's a voltage issue ( but possible )
    If a shop did the work and provided parts then one hour is a short time to let unit sit there and run ( high idle ) if they want to throw another clutch at the rig. SM should be smarter than that.
    JMO bud, good luck
    Bean Jr. and bzinger Thank this.
  4. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    A weak high or low pressure switch will cause the compresser to cycle constantly and burn a clutch. Mine had a bad Schader valve that the core was bent and caused my clutch to fail.
  5. AModelCat
    154,240
    Very unlikely to get 3 NFG clutches in a row but stranger things have happened. How is the clutch air gap? Some of them you need to set the gap with shims. Too tight of a gap could cause it to drag when disengaged and too much gap could cause it to possibly slip under load.
  6. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Sounds like you got a bad compressor. If I understand your situation correctly your saying you bought a new compressor and air dryer and clutch. Then you went through 3 clutches. If that's the case then the compressor that was put on is bad. 90% of the time it's because of a reman compressor. If your saying that you bought a brand new compressor, then it's time to get on the horn with their warranty department b/c they owe you a new compressor and clutch.
    My money is on the shop you went to using reman parts and you got a bad one. It happens, getting three bad clutches is a long stretch.
  7. Offroadjack
    Offroadjack Light Load Member
    197
    52
    Jun 19, 2012
    or too much oil will burn the clutch up. has to work to hard to pump all the extra oil threw
  8. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Too much oil makes sense, but he said it burned the clutch up within an hour. Too much oil will shorten the life for sure, but losing a clutch in an hour is a red flag on mechanical failure.
  9. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Why did you replace the first one? What does the gauges look like? Is your engine fan coming on when head pressure gets high? Does the head pressure just keep going up even if the fan is on?
  10. Offroadjack
    197
    52
    Jun 19, 2012
    I have done it once in the past
  11. truckerbangin
    262
    44
    Jan 22, 2013
    Thanks guys i did all work in house. Installing new expansion valve and then going to recharge and check all system components. Was thinking it was either expansion vavle/cycling switch.
