Bunk truck rust proofing
Discussion in 'Canadian Truckers Forum' started by steve092, Nov 28, 2017.
  1. steve092
    steve092 Light Load Member
    298
    79
    Dec 7, 2015
    What's up fellow snow mexicans like myself. Has anyone here "pretty sure someone has" rustproofed their bobtail before winter time in Ontario around the GTA?
    I would like to have mine done but Rust Check does not do heavy commercial trucks.
    Thanks guys
    Cheers!
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Wtf is a snow Mexican. Lol
    Blackshack46 and sealevel Thank this.
  4. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    Krown does trucks
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Getting more and more common in the snow belt. Sucks working on it after though.
    rabbiporkchop Thanks this.
  6. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Aluminum cabs don't rust. Only old trucks had aluminum cabs. Century is last aluminum cabs I know of maybe Coronado. Not sure about newer Pete's or KW.
  7. Brucesmith
    Brucesmith Heavy Load Member
    728
    498
    Jun 16, 2012
    In my youth I managed a rustproofing shop. Had one month training in TO and Detroit. Is your truck metal cab?Lots of fiberglass these days. Pretty hard to do a OTR truck. You can do some measures yourself if you are patient The bottom of your doors should have some sort of drain. Use a small drift punch and open it up. You could take off the inner door panel and spray oil into the door. I see many Volvos that are eaten away on the doors. Spend some money on keeping the truck clean in the winter. Wash the underside. Never store your truck in a heated shop. It will rot in no time.
  8. steve092
    298
    79
    Dec 7, 2015
    Yeah it's metal a very small portion on the top is starting to rust. I also really wanted to have my frames all rust proofed since I had the entire truck sand blasted and painted
  9. liner
    liner Medium Load Member
    469
    676
    Mar 15, 2008
    ontario
    Sorry but your wrong.
    An aluminum cab will definitely rust.I just spent a bunch of money on my 2002 Peterbilt because of rust/rot whatever you want to call holes in the aluminum.
    bzinger Thanks this.
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    IMG_1358.JPG I’ve sprayed my own vehicles for years. Krown is a great product. I have a Napa spray kit. Not the best depending on viscosity of the products you spraying. Been spraying T-Rust tm with a Shotz gun lately.
  11. AModelCat
    154,582
    Paccar cabs are still aluminum.
    Steel rusts. Aluminum corrodes, which will turn it powdery over time.
