Bunk heater keeps dash lights on???
Discussion in 'International Forum' started by richi1052, Dec 9, 2021.
  1. richi1052
    richi1052 Bobtail Member
    5
    I am trying to run the bunk heater but whenever I turn it on the dashboard lights turn on also. And I am concerned the dashboard lights will drain the battery. By dashboard I mean the electronic gauge cluster. It will actually stay on even if I turn the bunk heater off. The dashboard lights seem to get stuck on sometimes unless I cut off the juice to the whole truck. Is this normal? Is the electronic gauge cluster going to drain the batteries? This is my 1st night in this truck. Thanks.
  3. flood
    flood Road Train Member
    4,157
    4,021
    Dec 25, 2010
    if it drains your batteries you need new ones.... you can run the bunk heater all night with your parking lights on and it's start just fine...
    richi1052 Thanks this.
  4. IGOR-UA
    IGOR-UA Bobtail Member
    14
    19
    Jun 30, 2013
    YONKERS, NY
    I have same issue, dash board lights on and front cab heater fan on. How to save batteries? After 8-10 hours Webasto drained brand new battery to 10.9v-11.8v.
    In my previous Cascadia I disconnected one extra cable from the ignition key to keep the APU and Webasto running with the engine running.
  5. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    What model, year is the truck?
  6. richi1052
    5
    2020 international. I don't know the model but it says LT on the hood. Old timer at our company said it's normal...
  7. Heavyd
    7,751
    6,184
    Feb 4, 2009
    I don't think this is a defect, the dash lights do come on when the door is opened. With the front blower on the body controller is functioning which will wake up the light control module. The dash lights are all small micro LEDs and do not draw much current, so they should not cause battery draining. You can turn down the dimmer dial on the light control panel where your headlight switch is to minimize the light if you like.
  8. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    If it really bothers you you can remove the feedback wire at the body controller from the bunk heater. I don’t recall what terminal it is though.
  9. 10bushmich10
    10bushmich10 Bobtail Member
    Heavyd, I have a 2023 lt and the front lower doesn't turn on when the sleeper no idle heat is on. Has the factory battery apu. My 2020 did and it did a great job in the winter keeping the snow and ice clear from the windshield. At the dealer now and they are back and forth with engineers since they are clueless as to why there is no power going to front blower moter with sleeper heat powered up. The manual states this option is supposed to work. And help I can pass to the dealer?
  10. Heavyd
    7,751
    6,184
    Feb 4, 2009
    I haven't seen this behavior with 23's yet. This will be a learning opportunity for us both.
    Oxbow Thanks this.
