Hello All!! I have a 2015 Freightliner Cascadia Sleeper Cab. The other day after shutting down for the night i noticed a coolant leak right underneath the drivers side door. Upon closer inspection it appeared that the coolant hoses running from the bunk heater are the culprit. Does anyone know exactly what they are called cause I called Freightliner and what they wanted to sell me was a set of $231 hoses with steel attached and from what I see all I need are the rubber hoses. That’s it. Maybe I’m wrong but if someone on her can direct me as to exactly what I need in order to fix this I will be most appreciative. I’ve included pictures to show the hoses. All responses are appreciated. Thanks in advance.
Bunk Heater Coolant Hoses Leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DaTruckerMan, Feb 15, 2024.
You don’t need the hard lines we normally replace heater hoses with the blue heater hose commonly available. Grab a string and use it to check length of both hoses . Measure string and buy a foot extra . A few worm clamps and you’re set . If you have heater taps shut them off and do repair if not drain some antifreeze into a clean container. PS it could be a loose clamp or heater core leaking . This work can be done anywhere or by yourself. No need to pay high shop rates any mechanic can handle it ..
Jordonh, BoxCarKidd and DaTruckerMan Thank this. -
DaTruckerMan Thanks this.
Thanks…That’s why I came on here cause if I would have listened to the Good Folks at Freightliner I’d be $231 poorer and probably wouldn’t have the right part on top of that. I’m all about keeping my money in my pocket. It’s looks and feels way better than putting it in someone else’s pocket lol Thanks again!!!
Magoo1968 Thanks this. -
Cheap ### hose clamps on there by the looks of it.
Jordonh Thanks this.
