bungees for chaining
Discussion in 'Experienced Truckers' Advice' started by deerslayer1543, Apr 26, 2013.
  1. deerslayer1543
    deerslayer1543 Light Load Member
    57
    10
    Jan 21, 2010
    topeka kansas
    what length bungee works best for tire chains?
  3. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    It really doesn't matter that much, I've used both. Even a 24", you just pull it through one place and hook it across the wheel. Something I have seen but never tried are those "spyder" looking units designed specifically for tire chains. Sort of an all in one bungee strap that hooks on all around the wheel. They look like they might be the ideal thing. Only thing about them is they work only on the outside, whereas the basic straps can be put on the inside too, to hold your extra links from slapping around and catching something. Take a bit of extra time to get everything good and tight, and you can almost make those chains "sing" you a tune. Nothing sucks like having a set come loose, and either come right off, or end up hooked around the axle dragging, esp. in mud.
  4. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    those octupus bungees appear to be the hot set up at the moment
    dont strech out too much either
  5. Ezrider_48501
    3,844
    5,135
    Apr 2, 2011
    bismarck, nd
    a bungee about 6 inches shorter than your rim size. but like the last poster said, if the ones you have are too long you can pull them threw and then re hook them. I have never run the spider type myself but know some guys who have and the seem to work really well and they seem to eliminate popping bungees when running on chains for extended periods of time like you will with tarp straps because they don't rub on each other in the center like tarp straps do.
  6. seabring
    seabring Road Train Member
    1,844
    1,886
    Apr 24, 2011
    I bought a new set of chains last year and got the spider type bungees. I like them better than single bungees , they are quicker to
    put on and easier to store in the side box without becoming all tangled up.
  7. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    I think those are good ones but they break kinda fast:p $20 for one and they break often. its cheaper to buy the singles and do it. i use the 18inch ones and loop it
  8. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    I thought it was time to put the chains away already u guys still getting snow in the east?
  9. bigdogpile
    bigdogpile Road Train Member
    1,931
    1,463
    May 16, 2010
    fontana ca
    I heard if you put your chains on properly, you don't need bungees
  10. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Truck shop I used to work at used those spider style bungees to secure the chains on the maintainer they used to clear snow in the winter ( run-on much?). Seemed to break often, but they were on the machine all the time, while drivers I've talked to don't chain up that often, or for very long, so they might work better for a truck.
  11. Trucker Bug
    Trucker Bug Light Load Member
    117
    86
    Jan 24, 2013
    California
    I've used the 24" ones. If you get them on right you don't need bungees at all. I've ran 73 miles straight before and never had a problem.
