broken zerk on u-joint
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Sep 4, 2020.
  1. rollin coal
    rollin coal Road Train Member
    13,083
    25,890
    Mar 29, 2008
    TN
    I've got a grease zerk and the nipple is broken off of it (wtf?!). Hoping I can get it out easy with an ease out. Anybody ever use one of these tool to extract one? Are they any good? This one is too large just posting it up to ask about the tool. Grease Fitting Multi-Tool (Large)
    blairandgretchen and 650cat425 Thank this.
  3. AModelCat
    154,482
    Changed many broken ones in a u-joint before. If they're full round yokes I've had great success with ez-outs. Even the back end of a chainsaw round file will work in a pinch.
  4. rolls canardly
    rolls canardly Road Train Member
    1,598
    3,727
    Feb 7, 2009
    mt. pocono. pa.
    They are a tapered thread - so if you get it to turn, you just spin it out.
    This is a trick that is not for those that are mechanically challenged.
    I have a set of left hand helix drills, (Tool and Die maker 40 plus yrs.)
    and had occasion more than once to need these to get out of trouble.
    Use a smaller size of a left hand helix drill, and run drill in reverse.
    I have a yellow Dewalt cordless with a hi/low switch on top of it.
    Start the drill in low speed setting, and just lightly jab it into the fitting, so it catches rather than drilling - and it backs it right out. Don't try that trick on harder metal, or it may break the drill bit,
    and of course, always wear eye protection.
  5. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    Get out the "heat wrench" before turning the easy out.
  6. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Old flathead screwdriver ,the tip needs to go in the small hole in the middle,that you tap gently in.
    If needed grind it down at the tip to fit.
    Put a vise grip on it if you can't put enough power on the handle.
    I have used that trick several times.
  7. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    I had one broken zerk that I removed by hammering a torx bit into the hole and unscrewing it. The easy out I had did not work, and it was too close to the ground to get my drill in it. I think T20 was the size I used, like what is used for deck screws.
  8. 86scotty
    86scotty Road Train Member
    4,375
    11,615
    Aug 27, 2017
    Appalachia
    You guys are confirming that my fixes are less ghetto than I thought.
    Pretty often I pick up a tool which has been cut on or ground on for some specific reason and I think "oh boy, I remember that day!"
  9. Snow Hater
    Snow Hater Medium Load Member
    480
    977
    Dec 26, 2019
    I prefer to be called a shade tree engineer.
  10. blairandgretchen
    13,231
    70,453
    Dec 9, 2011
    South west Missouri
    It’s not a ‘Rangi Job’ if it works!
  11. Michael 247
    Michael 247 Heavy Load Member
    857
    4,357
    Nov 20, 2017
    Dublin Va
    I call it Appalachian Engineering
