Broken Landing Gear
Discussion in 'Questions From New Drivers' started by copperdome, Oct 12, 2019.
  1. copperdome
    copperdome Light Load Member
    80
    100
    Oct 10, 2019
    I am having a hell of an evening... I can’t get under this trailer. The landing gear on the one side won’t go up whatsoever and the tires wont even go under the trailer on the broken side. Any ideas on what to do? There is a forklift there... I have a jack but only 2 ton, not 20.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Assuming that the side with the handle is the one going up, look and see if the pipe crossing to the jack on the other side is turning the jack input on that side. I have had the bolts that run through the pipe and input on the jack itself shear, to where it is not turning the jack.
    If everything is turning, then it is time for new landing gear.
  4. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Try goin at it on the broken leg side corner of nose with the air ride down and gettin at it with the 5th wheel..
    If its really rubbin the tires hard then either a tow trk to lift it,shunt trk with lower profile tires or fork lift..
    If its just gonna scuff the tires a lil then its your call to ram it sorta speak..
    x1Heavy and FlaSwampRat Thank this.
  5. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Then do what with the leg that won't come up?
    Have you dropped the air to where you get the back part of the frame under it, then put a piece of dunnage on the frame and raise it. it usually takes 2 or 3 times with different boards to get one high enough like this, and helps if both legs works, but it can usually be done. If you can't get it working and get hooked up, I would tell them to fix it before I tried forcing it and breaking something, but that is me, and I am not there.
    x1Heavy, Tx Countryboy and FlaSwampRat Thank this.
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Leave it alone and let the owners fix it.
    You get hooked up to it. Then what you gonna do. You can't get the gear to work. And what you going to do when it's time to drop it.
    That trailer is OOS. Just leave it alone.
    Unless, of course, you're taking it to get fixed.
    x1Heavy, mjd4277, spindrift and 5 others Thank this.
  7. craig_sez
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Yeah i use to have a cpl blocks of wood just for such issues..Oh sorry must missed the part about the leg not commin up...Then again how do you know if your not under it...
    If its busted,call a service trk to fix it..
    FlaSwampRat Thanks this.
  8. copperdome
    80
    100
    Oct 10, 2019
    Update: I’m hooked up to it and pulled over because that side of fell down. When I got to the yard this morning the trailer was sitting normal and I assumed it was fixed. I will check the bar that goes across now.
  9. kemosabi49
    10,435
    44,384
    Jan 13, 2013
    SW Arkansas
    Don't assume. Check things that should have been repaired. Always. If you had taken the time when you got to the truck this morning to run the legs all the way down and back up, you would be better off now. Always double check.
  10. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    And never, ever force anything.
  11. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Well if they fixed it supposedly and it fell back down, personally I would drag it a few feet,THEN call them and they WILL fix it. lol
