Broken Axle or Shelled Rear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ExtendedHoodPete, Mar 17, 2015.
  1. ExtendedHoodPete
    ExtendedHoodPete Bobtail Member
    16
    13
    Mar 11, 2013
    I bought an 84 Pete 359 EXHD from a guy here in town and he kind of abused the poor truck. When I bought it I knew the main drive was bad but bought it anyways as it was cheap and I was looking for a project truck (and I'm a sucker for 359's). It'll drive with the power divider kicked in but I haven't driven it more than a few miles to the lot it's at now because the good drive cracks and pops which I believe is the power divider jumping gears.
    The man I bought it from pulled an end dump. He said his driver got off in some mud one day and got stuck and dumped the clutch a few times trying to get free...
    Anyways, I haven't had a lot of time to work on it but once every now and then. I've been thinking I needed a new set of rear ends and it probably shelled some spiders but when you jack the main drive (the bad one) up in the air, you can spin the wheels freely and it's dead silent. I've had a few guys tell me if it was the rear end then you'd hear and feel it cracking and popping and that it was more than likely an axle. When I disengage the power divider and let the clutch out where I should be moving, it does nothing but spin the drive shaft. No popping or cracking can be felt or heard. When you jack them up in the air and spin them by hand, the other side starts to spin opposite for a few seconds, then it slows down and stops, either way you turn them. I want to say if you spin the right side the left side doesn't move at all but I don't remember for sure. I've been meaning to work on it more, but it's been too cold and crappy outside or I've had other more important things besides my huge hot rod. I've had the passenger side axle out to change a gasket but that's it. It was fine.
    I guess my main question here is, what are y'alls opinions on it? I know I won't know for sure until I get that axle out which will be this weekend. I've had multiple shops tell me it's more than likely an axle including Inland Truck Parts. That would absolutely make my year. If it matters, the truck has a 3406A, 12513 with Rockwell SQ100's-unknown ratio, truck has a cutoff.
  3. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Sounds like maybe a broken throughput shaft? I would drop that rear drive line, remove the yoke and check that throughput shaft and bearings before I did anything else.
    Could also pull the drain plug and see if any metal parts are stuck to it, might be some clues as to what all went on in there.
  4. Righand81
    Righand81 Bobtail Member
    7
    4
    Feb 28, 2015
    South arkansas
    Being that it's a project just go ahead and pull the power divider and check it out first. U won't be out anything but a tube of silicone and a little gear oil. Projects need to be looked at!!
  5. Ringo1
    Ringo1 Light Load Member
    89
    131
    Apr 20, 2014
    South Carolina
    I've seen that with a 6X4 dump, driver had to lock the power divider to get the truck to the shop. Broken axle shaft on the drivers side.
    Hope that's it and a lot cheaper fix, good luck!
  6. Mr.X
    737
    596
    Oct 31, 2013
    Spokane, WA
    Last winter I had my 3 rail chains on, one skidder pushing, and one skidder pulling. when we got to the top of the hill I had the front axle with one tire that would spin (least traction).
    Truck couldnt move without interlock. Unloaded at mill, bounced home, replaced throughput shaft, pulled plug while holding rag over hole, removed chunk of steel from broken throughput shaft, and went back to work the next day.
    Not to many things it can be, but if they aren’t lockers then the one wheel spinning on each axle is normal.
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    if your lucky they just snapped the axle shaft. just start pulling axle shafts out, in only takes a couple mins don't even have to jack the tires off the ground. take the bolts out of the flange a couple taps to break the seal loose and slide the axle shaft out. if your lucky you will pull one and it will be in two pieces.
