Brakes rusted to drums
Discussion in 'Experienced Truckers' Advice' started by AVL, Jul 13, 2020.
  1. AVL
    AVL Bobtail Member
    39
    44
    Jun 30, 2018
    Just on one side of the axle and only lower brakes are stuck/seized. Upper brakes are fine
    Was hammering it for hours for two days (with brakes released of course), sprayed some brake cleaner and acetone with no luck. Tried crow bar on the sides of the shoe lining, wouldn’t move. Truck has been parked since winter.
    Any recommendations?
    Mechanic said he could cut the spring tomorrow just to get it in the shop but the brakes would get damaged and will have to put new ones. Will cost few hundred, but at this point I’m ok with it. Does that make sense what he is trying to do?
  3. AVL
    AVL Bobtail Member
    39
    44
    Jun 30, 2018
    Also, since upper brakes aren’t stuck I’m assuming relay/quick release valve is fine
  4. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    Cage the brake chamber then check the S cam
    Rideandrepair Thanks this.
  5. kylefitzy
    kylefitzy Road Train Member
    4,645
    19,222
    Aug 12, 2007
    Kansas city,Mo
    If it’s a drive axle, release the brakes, lock the power divider in, and slowly apply pressure in reverse. I’ve never had a rusted set not come free in reverse.
  6. 201
    201 Road Train Member
    12,296
    25,115
    Apr 16, 2014
    high plains colorado
    Yep, I bet the S cam is turned over.
  7. AVL
    AVL Bobtail Member
    39
    44
    Jun 30, 2018
    @flood
    If S cam is turned over, would the upper brakes still operate? Thanks for all the replies
  8. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    AVL: if it sat all winter, usually the bottom pad gets all the icing and rust more than the top.
    With a dust shield in the way, it’s harder to beat the pads loose.
    no dust shield, much easier.
    Like Semi retired said, if the cam is almost turned over, the roller could be stuck on the weld or lip of the cam preventing it from turning back.
  9. AVL
    AVL Bobtail Member
    39
    44
    Jun 30, 2018
    No dust shields, hammered under the truck, outside through the rim holes with a winch bar and a hammer. That thing just won’t release. Waiting for mechanic now
    Didn’t help, will post back today on the solution we’d come up with.
    Rideandrepair, Shawn2130 and kylefitzy Thank this.
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    The bottom seizes because thats where the water runs down (to the bottom of the drum) and forms rust, and ice weather permitting . When you set the brakes it forms. Not much rust but just enough. Other than hammering on the side of the brake shoes, and drum dont know except get a acetylene torch and gently heat the drums. Never tried the heat thing..but i would before i cut brake springs etc. Note to self..ride your brakes before you park next time to heat them up and dry them. After i do that i don't set them. Winter time is bad also for this issue. I leave trk in gear, and sometimes drop the landing gear to keep it from rolling. Wheel chocks and level ground obviously better also.
  11. flood
    4,161
    4,031
    Dec 25, 2010
    or rusted.. had it happen
    Rideandrepair and 201 Thank this.
